Question about EZ Tankless 1 - Meter Direct Vent Extension Pipe
Ez tankless deluxe e1 error codes - EZ Tankless 1 - Meter Direct Vent Extension Pipe
I have a paloma ptg2-42pvn tank less water heater. I recently installed the remote as the unit quit making hot water. I wanted to see if it was producing a code. The remote is flashing 76 repeatedly. I...
Bad remote control. Bad wire to remote control. Bad PC board.
Copy following link for resources, including older service manual and error codes and rheem chat for ordering replacement motherboard for your tankless computer.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If tankless computer is 5 years old, then compare that to your 5-year old cell phone or 5-year old laptop, and ask if the chipware still functions or can be repaired to function back to factory fresh expectation.
Later today, install tank type water heater and solve all tankless computer problems with one ez step. Have hot water for shower same day with less maintenance and fewer long-term problems and expense.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 24, 2013 | Water Heaters
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
Water not as hot as it was.
Tankless require yearly service to keep burner and combustion parts clean and check electrical connections, gas solenoid, gas pressure, venting, etc.
Read product manual for advisories and recommended maintenance.
Yes, aren't you glad you saved the manual.
Always check that local area has affordable and qualified service technician for your brand before buying tankless.
Before calling service technician, copy following link for general troubleshoot resources, including some manuals, and links to Bosch.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Try turning temperature down.
The fact there is no error code, and the gas is not firing correctly, means you have a small unit with no error codes and PC board has failed ... or it means you have a unit with error codes and possibly bad PC board.
If problem is the PC board, then Bosch will send you new board, and expect same level of repair success as though your computer's motherboard was replaced.
You can buy ordinary box-store tank-type heater and install yourself same day for about $325.
Then maintain and fix it yourself. I recommend AO Smith/American/State/Reliance/Kenmore/Whirlpool since these are easy to maintain with clear directions in manual, plus AO Smith posts service manuals for the whole line of products, and any local plumber can fix them with ez-to-locate generic parts.
Sep 07, 2012 | Bosch & Tankless Water Heater
Rheem Pronto water heater Error code E1
Before calling service technician, open following link for troubleshoot resources include Rheem chat, error codes, and regular maintenance manual, and possible product manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Clean the water filter as shown in product manual.
Error E1 is not specifically shown for Rheem/Pronto tankless.
1 is usually related to water flow.
E errors are related to temperature, so E1 can be temperature sensor failure on hot water pipe.
E errors can be loose/bad wiring or part failure.
Error codes are considered start-point for troubleshoot.
Each tankless manual recommends cleaning the water filter monthly, deliming heat exchanger yearly, and cleaning combustion chamber and burner parts yearly.
Regular maintenance can prevent most common error codes, but the cost and nuisance will outweigh expected $1-8 monthly savings on gas bill.
The requirement for continual maintenance should signal folks that tankless are not effortless hot water as described in tankless promotion.
Solve most tankless problems same day, yourself, any brand, using minimal tools for about $350.
Oct 02, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Error codes E1 and most recently EC. We have been geting fluctuating hot and cold and now only cold water. I have replaced the OTS, cleaned the inlet filter screen, descaled the tank, with no success. ...
You had service techs and Bosch techs and neither can find a solution.
I assume you want impartial opinion at fixya.
Multiple error codes and a lack of progress by professionals implies PC board failure. BUT there could be multiple problems. Error codes are considered 'start' point for troubleshooting. Beyond that, Bosch should give you contact information to a trained professional service tech >> not just a plumber, but a guy who can do the electronic diagnostic.
Open following link for Bosch troubleshooting resources.
Tankless are high tech gadgets that cannot be exposed to more than 11 grains hardness in the water, and require continual maintenance. The cost of repairs and maintenance will never pay back from the expected $1-8 monthly energy savings.
You can solve most tankless problems same day for $350.
Then sell the tankless unit back to Lowes or sell it for parts on auction site.
Jul 21, 2011 | Bosch 2700ES-LP Propane Tankless Water...
EZ Tankless 1 - Meter Direct Vent Extension Pipe Logo
49 people viewed this question
Top EZ Tankless Water Heaters Experts
Donni Steen
Gil Shultz
Are you an EZ Tankless Water Heater Expert? Answer questions, earn points and help others
