Question about Versacheck VersaInk-nano Universal Refill Kit - Black - MICR Compliant
Versaink not readable by check scanners - Versacheck VersaInk-nano Universal Refill Kit - Black - MICR Compliant
Our HP 3015 fax is not sending a readable fax at the receiver's machine. About half the page is readable, and the other half has a series of horizontal lines which makes the balance of the page unreadable....
it only happens when you have something on the scanner
Over time, specks of debris might collect on the scanner glass and white platen, which can
affect performance. Use the following procedure to clean the scanner glass and white platen.
1. Use the power switch to turn off the product, and then unplug the power cord from the electrical socket.
2. Tilt the device control panel forward.
3. Clean the glass strip and the white platen with a soft cloth or sponge that has been moistened with nonabrasive glass cleaner.
hope it solve the problem, if so rate the solution
Nov 22, 2010 | HP Office Equipment & Supplies
My girlfriend has a versajet m400 printer. Is the
Yes the cartridges are correct. Black is 34MS/Mx and Color is 35 or 35S, full details below..
  • 1.0 x Cartridge ( Color ) - VersaInk 35S ,
  • 1.0 x Cartridge ( Black ) - VersaInk-nano 34MS
Combo Cartridge Pack here: 5b1f12c.jpg
Good luck.
thanks for using FixYa.
Jun 23, 2010 | G7 Productivity Systems VersaJette M400...
What black ink is used in the versajette m300
Hi
It is 34MX Black Ink Cartridge and you can click on here see click the links 2 there for you.
also I belave that lexmark made the printer so maybe you can get from them the ink.
http://shopper.cnet.com/peripheral-accessories/g7-productivity-systems-versaink/4014-8309_9-33365115.html
And this one
http://www.microcenter.com/single_product_results.phtml?product_id=0264279
Feb 07, 2010 | G7 Productivity Systems VersaJette M300...
Why I am unable to send scanned messages by email succussfully, they are not readable by the recipient. I can scan and copy and send successfully, as an email attachment, but the recipient says the print...
hi, do check ur scanner settings. It is advicable to save the scaned image as a JPEG and then u can easily mail it. Do set the are the scanner is goin to scan perfectly. and see to u do not interupt he scan before u get the image on ur computer. If the problem persists do post again.
Jul 08, 2009 | Office Equipment & Supplies
Enabling NCR 7875 flatbed scanner to read Code 128 barcodes
On a 7876, you need to scan the sequence “17130” is to add 128 tag readability. Not too sure if the 7875 is the same.
Feb 18, 2009 | NCR 7875
Out of original Versajette Ink
Not,. Also you need the original versaink.I think because it is specilly designed for checks.
Feb 15, 2009 | G7 Productivity Systems VersaJette M300...
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Failure to open OCR documents scanned into Microsoft Word in a readable format
Have you installed OmniPage? What OS are you using? Which scanner did you have previously? Are you able to OCR a document through OmniPage?
Jul 26, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Versacheck VersaInk-nano Universal Refill Kit - Black - MICR Compliant Logo
42 people viewed this question
Top Versacheck Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Versacheck Office Equipment and Supply Expert? Answer questions, earn points and help others
