Question about Diesel DZ7259 Watch
Reset the chronometers - Diesel DZ7259 Watch
How do I set the chronograph on my manual Omega 1964 Seamaster wristwatch?
The chronograph resets at 0 on the recorder hands and the crono hand resets at 12:00
hope this helps.gabe
Oct 20, 2014 | Omega SeaMaster Watches
Tip
Chronometer disassembling/assembling/use.( Valjoux/ETA)
Follow this link and see how to disassemble/assemble automatic chronometer movement. Learn functions as well. <a href="http://www.eta.ch/swisslab/7750/7750.html">http://www.eta.ch/swisslab/7750/7750.html</a>
on Feb 26, 2011 | Watches
Tip
TAG HEUER automatic chronograph-chronometer manual.
Follow this link and download original manual for C.O.S.C. certified TAG HEUER chronograph-chronometer: http://www.tagheuer.com/the-collection/link/men/calibre-36-automatic-chronograph/index.lbl?w=CT511A.BA0564
on Feb 09, 2010 | Watches
How to reset my Burberry watch BU1205
To reset the time you pull the middle dial out a bit and twist it around to get to your desired hours and minutes. To reset the chronometer you need to press the start button until it stops and then the other button, known as a reset button.
Jun 09, 2014 | Burberry Watches
I just bought the armani ar0142 but the second hand doesn't work. Is this normal?
Take closer look and you will notice the small seconds hand which should be working. The dig seconds hand actually is chronometer hand and will work only when the chronometer function is engaged. Push the top button once=chronometer will start. Push the top button once more=chronometer will stop. Push the bottom button once=chronometer will return to zero. Rate me, please.
May 18, 2010 | Giorgio Armani Emporio Armani Black/Steel...
I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Mar 31, 2010 | Tag Heuer Link Automatic Chronometer...
Festina chronometer. The hand that shows .01 secs does not return to 12 o'clock position. I would like to reset it if it is possible to do it using the buttons.
In chronograph mode but not running use the top left button 1 press at a time to advance the hand to the 12 o'clock position. Then return to normal moe - job done.
Jan 17, 2010 | Watches
Chronometer won't start
Not sure this is worded right. A chronometer is watch that has been certified by a Swiss organization to keep time within a set +/- seconds per day in several positions and temperatures.
A chronograph on the other hand is a watch that has push buttons on the side for starting/stopping/resetting a set of hands to mark time elapsed.
If this is truly about a chronometer not starting it is either a broken part or needs cleaning.
If it is about the chronometer not starting most likely if it is a mechanical watch the pusher is stuck or broken or a lever is out of place or bent. If the whole watch does not run then it could be a broken mainspring.
If it is a quartz chronometer it could be a bad battery or if the battery has been changed it is most likely the person that changed the battery has damaged one of the coils and or circuit.
A qualified watchmaker can help with any of these problems.
Hope this helps,
Ken Kotoski
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 28, 2009 | Breitling Watches
The Tag Heuer Chronometer simply did not function at all
I'm not sure this will help, but try to reset the watch completely. Use users manual how to do that.
Sometimes it does the job.
Dec 22, 2008 | Tag Heuer Link Automatic Chronometer...
Diesel DZ7259 Watch Logo
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
