Question about Logitech HARMONY 659 Remote Control
Volume down button is not working
Can you repair or tell me how to repair?
  • 43 Answers
Power reseting it should work, pop out the batteries, press every button twice and put new ones in, if that doesnt work a solder joint might have come undone, if your a techypop it open, if your not please do not risk voiding your warranty and call logitech fr a replacement or take it back to the store
Posted on Jan 24, 2009
How do I program my tv remote
HI,
DIRECT CODE ENTRY
Step 1:Press and hold the "CODE SEARCH" button ("CODE.SRCH" for RCU500).
Step 2:Press and release the device (VCR, TV, Cable etc.) button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 3:Enter the 3 digit code number
Step 4:Release the "CODE SEARCH" button.
Step 5:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test.
CODE SEARCH
If you cannot locate the code for your device, try thecode searchmethod below:
Step 1:Turn on the device.
Step 2:Press and hold the "CODE SEARCH" button.
Step 3:Press and release the VCR, TV, Cable or Audio button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 5:Press "ON/OFF" (or "POWER" for RCU500) repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button up to a hundred times (at a rate of once per second) if your code is towards the end of the preprogrammed list.
Step 6:When your device shuts off, press and release the "ENTER" button.
Step 7:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test, and if it does not function correctly repeat steps 1 through 6.
CHECK THE LINK FOR CODE
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE CONTROL 3 DIGIT...
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE 4 DIGIT CODE FOR...
Electronics Equipment Repair Center 3 DIGIT RCA UNIVERSAL REMOTE CODE FOR...
Sep 27, 2014 | RCA Televison & Video
The volume buttons on my remote for an amp won't work.
try a piece of alum. foil next time before you cut the buttons out---may still work with clear tape over it.
Nov 06, 2012 | Televison & Video
I have an audiovox dv7300 surround sound. When i turn the device on, the volume automatically climbs up to 50 which is the max. The volume knob will not bring the volume back down and the remote can bring...
1) retight the springs contacts batteries with pliers for a better contacts
2) open the r.control and clean the keypads very well from dirty, oxide, and bad contacts, with contacts cleaner.
3) otherwise you must go to the repair shop TV.
God bless you
Jul 09, 2012 | Televison & Video
Emerson EMP512-2 not working
1) change new batteries
2) clean contact very well from batteries
3) retight the spring contact batteries.
4) Resolder wires contact batteries.
5) Try again. otherwise you must go to the repair shop
God bless you
May 09, 2012 | Televison & Video
Volume not working. can it be repaired
Unfortunatly, Logitech does not provide repair services for Harmony remotes.
Did you try mapping the command to another button? Or you can create a soft button on the LCD screen for the volume.
Dec 15, 2009 | Logitech Harmony 890 LCD Remote Control
My volume and mute button dont work on my sky remote
panasonic
please follow the steps below:
TV
RED + SELECT
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 06, 2009 | Universal Remote Control Remote Control
The decrease volume button only works if you smash it
If it's out of warranty, take it apart and clean the parts.
Do a google search for cleaning tips.
My H628 had some dead buttons that didn't respond to cleaning, I used strong, thin double sided tape to attach a small piece of Al foil to carbon pad, then trimmed to fit. I did all the bad buttons and they all work now, at least till the tape falls off. If repair fails, I'll try foil and a dot of super glue and as a last resort I'll go for a $20 "Rubber pad remote repair kit". This is a silver containing paint that will restore the contacts.
Apr 23, 2009 | Logitech Harmony 550 LCD Remote Control
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing...
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Mar 02, 2009 | Logitech Harmony 880 Universal Remote...
Viewsonic remote RC00070P
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Jun 10, 2008 | Televison & Video
DVD Menu & Volume Control
i recommend getting a beafier remote some where in the 20 to 30 dollar range i owned one of these and they just sucked in codes and overall functionality i gave it to my dog went out next day bought a beafy remote
radio shack is not always up to speed on there equipment and sometimes outdated and a 7.99 uni. remote doesnt do it for me i think you can tell that by just being here on site asking for help
the remote bites
Apr 24, 2008 | Radio Shack (15-2147) Remote Control
Logitech  HARMONY 659 Remote Control Logo
356 people viewed this question
Top Logitech Televison & Video Experts
Brian Sullivan
Brian Sullivan
Terry Hair
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
