Question about Microwave Ovens
Need a replacement lightbulb for the Delongi AD1099 Rotisserie Oven and can't locate. It is not a microwave, though.
    Novelist:
  • 140 Answers
You can locate the correct bulb that you need at www.repairclinic.com. They have an extensive assortment for all appliances. When you search for your bulb keep in mind to put in the complete model # that is on your unit. Also this site can help you find a different replacement since it shows the type and size of bulb. Go by the wattage rating and what it looks like to fit right in. There are other similar sites and even belonging to Delonghi.com but I believe the repairclinic site is better.
Posted on Jan 23, 2009
How to replace lightbulb inside microwave
Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.
  • 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.
  • 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.
  • 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
  • 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.
  • 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
  • Oct 27, 2011 | GE JVM1860 Microwave Oven
    How to replace light bulb in combination oven model acm1580ab
    Cannot find your model number, please provide make and model.
    Jul 23, 2008 | Amana Microwave Ovens
    I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
    Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
    You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
    Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
    Euro-Pro Rotisserie Toester Oven. We need an operators manual for this unit.
    The only manual I could find was for the Bravetti Convection and Rotisserie Toaster Oven by Euro-Pro. Here is the site: http://www.sharkclean.com/manual/K4245H_REV_0405.pdf
    I hope this helps
    Jan 28, 2011 | Microwave Ovens
    TB6080A Welbilt Rotisserie Oven How to use the rotisserie oven
    I need a manual for my welbilt TB6080A I lost in moving. my Email is lorraineking8679@yahoo.com
    Jan 27, 2011 | Welbilt Microwave Ovens
    Replace a lightbulb in a microwave
    That's covered on page 24 of the owner's manual.
    If you've misplaced yours, you can download it online here.
    If you need to order a bulb or other part or accessory, visit here.
    May 31, 2010 | Maytag MMV5207A Microwave Oven
    HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
    The Viking VMOS200 is essentially a rebranded Sharp R-530E.
    One or both of these service manuals should cover disassembly and location of the bulb:
    http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
    http://www.microwavedisplay.com/r530es_sm.pdf
    May 28, 2010 | Viking VMOR205SS Microwave Oven
    Lightbulb on ceiling of oven went out. How do I
    Hello :
    1:Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
    2:Unscrew all the screws around the casing by turning them counterclockwise.
    3:Remove the cover by lifting off.
    4:Locate the light bulb in the microwave. This will be located on either the right or left side.
    5:Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
    6: Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
    7: Replace the cover and screw back on. You are now done and may plug back in the microwave.
    Warning : Unplug the microwave before starting and wait 20 minutes for any residual electricity to be bled off from the capacitor.
    Things you will need : Phillips screwdriver
    good luck .
    please rate !
    Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    HF87960GB Need to change lightbulb,how? Cant seem to locate it can anybody help please, Tony
    on the top of the oven there is a plate with 2 hex screws, just undo these and your see a bulb and BINGO!
    Oct 17, 2009 | Siemens HF87950GB Convection Microwave...
    Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
    Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
    Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
    Microwave Ovens Logo
    71 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
