Question about GE XL1800 1100 Watts Microwave Oven
Microwave locked Hi, I have a Panasonic combination Microwave. At the moment everything else is working but not the heating. I susepect it is locked somewhere but don't kow how to open it. Please help.
  • yangwei90 Jan 23, 2009
    Hi
    There is no error message. I can still use the Grill function, just can't get the food heated. A few weeks ago, somehow I maganed to get it working, and then it is not working again. The door is not locked.
  • Starnley Johnwells
    Starnley Johnwells May 11, 2010
    what error message do you have on your display window?
  • GE Master
  • 19,396 Answers
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 28, 2009
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
I have a Panasonic combination microwave, NNA753. The microwave has stopped working. When I put it on with 1/2 cup of water in it, it runs for 27 secs and then switches off. I have tried doing this...
Magnetron fault. This requires service through an authorised Panasonic service department as it is extremely specialised due to the type of technology employed with this machine.
The unit is not heating in the time set by the sensor.
Jan 19, 2011 | Panasonic Microwave Ovens
My Panasonic NN- 553BF microwave oven is not heating but all the lights and everything else works
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 21, 2009 | Panasonic Microwave Ovens
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Dec 17, 2008 | Panasonic NN-C980 Convection/Microwave...
Faulty Panasonic inverter dimension 4 combination microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Oct 20, 2008 | Microwave Ovens
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Everything works but doesn't heat up.
In this as in other inverter models, shutting off after 30 seconds (more like 20 in most cases) is usually a symptom of a bad inverter or magnetron. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter and other parts with him when he comes out to repair it. Might save you having it pulled into the shop. If you or a friend insist on trying to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts via Panasonic at http://www.pasc.panasonic.com/epartr
Apr 18, 2007 | Panasonic NN-S542 Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
76 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
