Question about Hozelock Plus Telescopic Lance Spray 2644
Hozelock lance 2644 trigger assembly replacement required
Hozelock telescopic watering lance 2644 mist spray blockage
Try soaking in white vinegar or any anti-water scale product. Misting requires a very small orifice and clogging is common. If you can back wash compressed air thru the holes, try that. A guitar string might be run thru the orifice and then back-flushed.
Oct 18, 2012 | Garden
Trigger stuck in on position on hozelock ultra 9
put some engine oil around it and that should free it off after a day or so
Mar 15, 2012 | Cars & Trucks
I have a Hozelock 2475. Which I need to have just bought a new hose for but i've mislaid the original assembly instuctions can I get same on line.
This is a link to a downloadable PDF file on our website , hope it helps http://www.hozelock.com/uploads/pdf/instructions/watering instructions/33714-002 2N1 REEL.pdf you can also get help from us on Facebook or at info@hozelock.com
Apr 19, 2011 | Garden
I bought a Hozelock Ultra 9 (model 2684) last year for watering the garden and cleaning the car.It now leaks very badly from around the trigger. Can I take it to bits and mend it? Are there any...
HI - Simon fom Hozelock. I am afraid they are not repairable in this area. The most common cause of this failure is due to ice forming inside the gun and forcing the internal plunger and O rings out - causing a leak. All sprayguns should be protected from freezing. If this isn't the cause (only you know !) And it is 1 year old, we would replace it under warrenty contact us for help www.hozelock.com for details. Simon
Mar 09, 2011 | Hozelock Garden
How do you assemble 2in1 hozelock wall mounted compact reel
how do you assembly the 2in1 hozelock compact reel
Mar 10, 2010 | Hozelock Garden
Bostitch framing gun
HI, if it happens when you press the trigger the top valve is sticking & your gun needs servicing.
If it is just leaking by itself the trigger assembly needs serving or you can replace the trigger unit. They are not expensive & come as a complete unit (depending on the model).
Moselikely the orings are worn out or dirty
cheers
Lance
Oct 08, 2008 | Tools & Hardware - Others
Hozelock Plus Telescopic Lance Spray 2644 Logo
Top Hozelock Garden Experts
richie46
Bill Boyd
Vernon Taylor
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
