Question about Samson MDR6 Mixer
How can I get a service manual or schematic for a Samson MDR6 mixer? Thanks!
One of the channels has a bad hum. It can't be heard when the channel fader is at minimum but increases as the fader is brought up.
SOURCE: Samson Servo 170 - 1 dodgy channel
http://www.soundonsound.com/forum/showflat.php?Cat=&Number=403253&Main=351397
Posted on Dec 17, 2007
mixculture
  • 14 Answers
SOURCE: Samson Servo 170 Amplifier
check see if youy have some coving the vent or the speak connect right
Posted on Dec 22, 2007
petraman7
  • 1175 Answers
SOURCE: Samson servo 300 right channel low output power protection on.
Hi...
This amp will need to be serviced
Check on the web for someone who does audio/stereo repair in your area
Posted on Jan 26, 2010
  • 547 Answers
SOURCE: Can you change the operating frequency of a Samson
No, the Stage 5 series are fixed-frequency units. They come in a variety of channels (the new 200Mhz range model has 28 different ones) but they're factory-set, and not programmable, so the frequency you pick when you buy one is the frequency you're stuck with.
Posted on Apr 08, 2010
petraman7
  • 1175 Answers
SOURCE: One channel of my Samson SX 1800 does not work. It
That section of the amp overheated and failed .
You're looking at replacing 8 transistors and a couple components on the protect circuit
Posted on Oct 05, 2010
How to connect a samson s mix 5 channel mixer
It depends on what you are trying to connect. The XLR would be a professional type microphone, it does not have phantom so a condenser mic will not work. The other inputs should match your stereo equipment. The output goes to your amp.
The Samson S-Mix is a miniature, rugged 5-channel audio mixer with 4-line inputs and a single XLR microphone input. The line inputs are comprised of two 1/4" phone and stereo RCA phono connections. Each input channel has a rotary volume control and the outputs include stereo RCA phono connectors and 1/4" TRS phone headphone output. The S-Mix is powered with an 18 volt AC adapter.
Mar 28, 2014 | Samson S-Mix Miniature Audio Mixer
Garbled sound
Much more info is needed.
Sep 29, 2013 | Samson MDR6 Mixer
Add to the question of hooking up 4 mic channels to a single compressor: I have a samson 16 channel mixer ( 8 mic inputs ) and a 4 channel compressor. I want to be able to use the compressor to compress 4...
Is there some reason you can't use one of you're aux sends for the compressor? You can then dial up as much compression as you want on each individual instrument. If you're determined to get the 4 mics into one compressor input.... Only thing I can think of is use TRS insert cables on the 4 mic channels - tie them all into one compressor input through a small patch bay or similar. Then bring your return from your comp to a 5th channel. Impedance matching is completely out the window so no promises on results.
Sep 27, 2012 | Samson TXM16 16 Channel Powered Mixer,...
Right side mix does not work
replace the output ic's it could be 4560 or else
May 20, 2012 | Samson MDR8 8 Channel Mixer
I have a Behringer PMP 6000 powered mixer. Channels 4 & 5 yellow overload light is constantly lit. No sound from either channel (just a faint hum when volume slider approaches max level...
There are NO "yellow" overload LED's period. The clip or overload RED LED's are just above the PFL buttons for selecting a solo channel. There are "yellow" signal received lights (level set) up near the trim controls. In normal operation these will light when signal is received. Here is schematic for the PMP5000 which is really identical for the 6000.
http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html This has part of the DSP and PS and the PA circuits.
Scroll down to "get manual" and click on it to download. Ignore other download links on the page.
Try turning off the Phantom power if it might be on... If that stops the hum, something is the matter with the bypasses feeding Phantom power to those channels... Possible problem might be shorting of one of the coupling caps at the preamp input. The PMH5000 drawings are more accurate at the input circuits. You will note that the level set LED's are the yellows, and the clip/PFL LED's are the red ones. I suspect that RF bypass caps such as C110 or C121 (example typical for channel one) might be shorted. This makes noise on the Phantom power line unbalanced and will get into the channel where one of these caps is shorted. Do a test: Plug a shorting jack that shorts the tip to the sleeve intot he inssert for the channel. With the LOW CUT button up, observe is the level set LED for that channel dims or goes out. If it does, then I supect you have a shorted RF bypass cap at the input..The next test involves driving a KNOWN balanced signal into the XLR jack and using a TRS in tthe inout 1/4 inch, test the levels with an oscilloscope to verify the hot and the return have equal amplitudes. I they don't, congratualtions you have to tear the main board out... lots of knobs and screws to access the inout circuits and verifuy the cause... it could ALSO be a bad transistor in the inout pair, etc...
Sep 24, 2011 | Behringer PMP6000 VP1520 PA Package
How do i hook up my mixer to a samson s.com plus compressor
Use INSERT cables to insert into the MAIN's. This will compress the whole level going to the mains.
Aug 04, 2011 | Samson TXM16 16 Channel Powered Mixer,...
Need assistance in learning how to use thepowered mixer txm20 controlls
Hi there. Just in case you haven;t got it, here's a link to the TXM 20 manual:
http://s3.amazonaws.com/samsontech/related_docs/TXM1620_OM_5L_v3.pdf
If you have this, then let me know what controls your are having porblems with and I will try to help>
All best
N
Apr 22, 2011 | Samson TXM20 20 Channel Powered Mixer,...
How do I connect my samson amp to my samson MDR10 mixer?
on the mixxer, use the "mix" "L" and "R" outputs. use 1/4 inch instrument cables, and connect the mox L and R to the amp's "channel 1" and "channel 2 inputs". always turn the mixing board on first, and the amp second- when turning off turn off the amp first, and turn off the mixer second. start with the mixer levels at the lowest, with the amp levels about 1/2 to 3/4 up. slowly raise the mixer channels first and then the mixer main volume until you have an adequate volume.
Mar 09, 2011 | Samson SX1200 Amplifier
Ch. 10 does not work - Mackie 1604-VLZ PRO
Yes, the ribbon cable is the 1st thing I would check. You can check the ribbon like this: Disconnect said cable from the channels. Connect cable connector from a known good channel to the problem channel. If channel sounds the same trace a signal through the channel op-amps.
May 26, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Samson MDR6 Mixer Logo
44 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
