How do i check the belts bush washing machine n146ca2
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I need a manual for a Bush washing mashine N146CA2
go to www. retrevo.com or www.fitness.manualsonline.com and download for free.
God bless you
Posted on Jul 13, 2012
Noisy washer removed back Took the belt off the drum and spun no noise Put belt back on motor and it made a noise so it identifies the bearings in the motor is the problem. Can these be repaired
can be the bushes if they at the end these can be changed not like the bearing in your other question. check the length of the bushes there should be around 8mm on them if they below 6mm they need replacing.
Jul 15, 2017 | Washing Machines
String stuck in washing machine
you need to unwind the string and any other blockage can be hard
sometime their is a need to dismantle and clean out all the bushes and bearings from threads hairs and also strings,
Mar 04, 2015 | Indesit & Philco Washing Machine Drive...
God bless you
Jul 12, 2012 | Televison & Video
Washer stopped working with low humming noise
Belt may have broken or come off, or idler seized or main support bearing siezed or even motor bushings may have seized. Best access is from above to check.
If you can spin the drum with ease from the inside, the belt broke or is off. If it will not turn, the motor bushings may have siezed, or the main bearing siezed.
Apr 12, 2012 | Kenmore HE2 Plus Front Load Washer
Hotpoint washing machine barrel not turning all other functions OK. Motor, belt drive and bushes look ok new curcuit board replaced any Ideas? Model wma64
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Feb 11, 2010 | Hotpoint WMA64 Front Load Washer
The washer wont spin.
it could be the bushes have woren out.
May 12, 2009 | Maytag Performa LAT2500A
Kenmore washer won't spin/lots of grease under machine
  1. It could be a broken drive belt, replace the belt.
  2. It could also be worn carbon bush's in the motor, replace the bush's
  3. It may be, the motor needs replacing.
Feb 21, 2009 | Washing Machines
Washer squeeks when drum rotates during wash cycle
The 2 bushings that mount the motor to the body of the washing machine are causing this.
You can get just the updated bushings, or a kit of 2 updated bushings and a replacement belt which is probably a good idea to replace as long as you are in there.
Remove the back cover and inspect the job. It's self explainatory and took me less than 30 minutes to complete.....and it worked on the noise :)
Dec 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
