Question about Pioneer Car Audio & Video
No display on tuner FZ94L
No display on tuner to tell me what station i am on
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How do I turn the volume up and down on a Kenwood tuner KT-56
Hello, according to the information I have, the Kenwood KT-56 tuner is just that. This means in order to have volume control you will need an amplifier. The KT-56 only allows changing of the stations, pre setting stations and may be a couple of more options. But it is only a tuner or simply put a display, now you need to put power behind it to make it put out sound.
Jun 17, 2016 | Kenwood Audio Players & Recorders
Sony MHC ec77 CD player works fine, great sound but when I switch to AM/FM, why is there no sound although the display shows that is going through the stations?
Unlike old analog tuners, the new digital tuners will not output any sound or static if they do not lock onto a station.
May 06, 2015 | Sony Audio Players & Recorders
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
Tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
Oct 06, 2008 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
AM/FM receiver
the problem is in your tuner for me it is betwen the IC and the IF transformer. if u cant fix it buy new stereo componet.
Apr 16, 2007 | Harman Kardon AVR 225 Receiver
VHF stations WILL NOT display. UHF stations WILL display. Have tried both the remote and the controls on the TV. What is the solution?
a no ufh channels would be a setting in the menu, but when your vhf channels go, the problem is typically the tuner itself, or the band switching ic. could be either. you will need a schematic to know what voltage is supposed to be on the pins.
Jan 24, 2007 | Zenith B25A10Z 25" TV
Car Audio & Video Logo
16 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
