Question about Galt Tea Set - Toy
Need instructions for galt paint a tea set
Help, I have lost the instructions and don't know if I can let my kids drink out of the painted cups or if I need to bake them first. Also is it possible to get more paint?
2 Suggested Answers
SOURCE: need new bungee for Galt trampoline
Galt was acquired by Elmer's Products. I was able to reach the company re. a new bungee for the trampoline by calling the following. They were very helpful.
For product or ordering information about GALT™ toys in the United States, please call 1.800.931.2218, or email orderdeskohio@elmers.com
Posted on Mar 08, 2010
What kind of health benefits does tea have?
There are many health benefits of tea, especially green tea which helps to prevent heart disease, cancer, cavities, gum decay problems, etc. I can say that there are numerous health benefits by taking different kinds of teas.
Jan 10, 2013 | Wine & Spirits
Tip
Generic, All Around Useful Painting Tips...
When faced with an expensive Paintbrush with dried paint, don't toss it, Save It...
  • Soak it overnight - Starting out with very warm Vinegar.
Now so it doesn't happen again...
  • Clean well, Place it into proper sized Ziplock Bag & then put into a Pringles, or Coffee can, Then cap it with the plastic Lid.
When storing a partially used can of paint, instead of just putting the lid on it,
  • place a sheet of plastic sheeting like Saran Wrap over the top, then press the lid on.
Instead of using the edge of the can to remove excess paint,
  • find a large thick Rubber Band, or Tie a wire or Twine over the top and bottom, exposing it over the middle of the opened can. Now just use that to remove excess paint & it will fall directly into middle of can and keeps can clean.
If your painted project appears a little rough after painting...
  • Don't use sandpaper or steel wool to remove roughness, that will leave scratch marks, even if gone over lightly, instead use Brown Paper Bag.
If going to apply new coat or 1st coat over metal,
  • wipe down really well with Vinegar. This will help keep paint from bubbling, chipping, blistering or peeling away.
To keep paint brush marks from being noticeable, especially on furniture or cabinetry, or Doors,
  • Use a product called Flotrol. This will eliminate streak and brush marks.
And one more tip
When needing to know what type of paint is on your project that you want to repaint...
  • Pour some Vinegar on a cotton ball, then rub on the paint. If cotton ball has paint on it, it is Latex, Not Oil based.
Happy Painting
on Jun 14, 2015 | Crafts & Hobbies
Rust around my bleach despenser and under the side of top where the despenser is help
Bleach tends to eat thru the paint and cause the rust. What I do on a call for this is to take the bleach cup out, sand the area and paint the area with appliance paint. Here is a link to the paint I use in case you want to do it. The only way to keep this from occurring again is try not to let the bleach get on the painted areas. I know this is hard to do on a washer but you can try to poor some water around the area of the bleach cup. If you should get the paint else where, be sure it is enamel appliance paint.
Nov 01, 2012 | Maytag PAV2300 Top Load Washer
I have the hds780rs0605 I need to know if I can use latex paint for my walls and how to with out it clogging up
Let me start by saying these types of paint sprayers are not usually recommended for painting large things like room walls because you're going to spend a lot of time refilling the paint cup. The cup only holds 20 ounces of paint and that won't go very far on your walls. If all your paint isn't mixed and properly thinned at the same time your walls could end up with a checker board look. You would usually be way further ahead to rent an airless paint sprayer.
If you have to use it; first run your paint through a paint strainer, avaliable at any paint or box store (The Home Deopt, Lowes, etc). Even new paint has impurities that will clog paint guns. It's highly recommended you mix in a paint conditioner like Flotrol but not absolutely necessary. Next, you're going to have to experiment with the consistency of the paint to get a good even flow out of the gun. The thinner you have to make the paint to get a good flow, the lighter and more coats you're going to have to apply. It's also recommended to run a paint soaked roller over the wall right after you spray it to even out the paint and remove any overlap marks.
Aug 05, 2012 | Air Tools & Compressors
The flat screen tv was sprayed with paint right across the screen we need to know if there a way to get it off.....my email address is chiefgabriel@hotmail.com
buy a solvent called paint thinner from paint selling shops .............. using this paint thinner easily paint on your tv screen can be removed without any damage to screen .......remove tv powercord from power socket ......take thinner in small cup ...... take a small piece of soft clothe ..... dip in that cup such that soft clothe becomes just wet ....then slowly clean that particular place where paint is there .....same time keep another soft dry clothe in your other hand ......while cleaning with thinner paint on screen becomes thin then immediately clean it with other clothe..........remember while cleaning thinner's drops should not fall down & go inside tv through edges of screen ....... since this thinner smells like a paint after cleaning tv screen will have paint like smell ..............so again you have to repeat above steps but this time you have use soap water or any ordinary cleaning solution ....................................... click below shown link for images of thinner..... http://www.google.co.in/search?hl=en&q=paint%20thinner&rlz=1R2SUNC_enIN399&gs_sm=e&gs_upl=0l0l0l156l0l0l0l0l0l0l0l0ll0l0&bav=on.2,or.r_gc.r_pw.&biw=1024&bih=418&wrapid=tlif131594078475010&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi
Sep 13, 2011 | Samsung Televison & Video
Hey yall i got a sharpe finex3000 hvlp spray gun model sh-880 1.4 finish gun. and ive used this gun before and i cant remember how 2 set it up etc or what the best working pressure is. anyways i was tryen...
There is a step by step description in the manual of the Finex3000 itself (incl. pressure set-up, etc...). In case you don't have it anymore, you can look online: http://sprayfinishingstore.com/manuals/
Jul 25, 2011 | RTO Sharpe Finex 3000 Hvlp Gravity Auto...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
I am pregnant,Can i drink tea or coffe?
When pregnant, you should limit your caffeine intake. Tea has really low amounts of caffeine, so a cup every so often probably wouldn't be a problem.
Coffee however contains a lot of caffeine so it would probably be best to avoid it most of the time.
Mar 05, 2011 | Lands Phones
I have just purchase a Wagner W550 electrical spray gun. Not having used one before I need to know how do I know if the coating mayterial need to be diluted and if so by adding how much solvent. I intend...
Have a look at the instruction manual. It should state the viscosity that the paint should have. Use a viscosity cup to measure the time the paint takes to drain from the viscosity cup. Dilute the paint if it takes too long.
Nov 24, 2009 | Wagner Air Tools & Compressors
Galt Tea Set - Toy Logo
111 people viewed this question
Top Galt Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Galt Toy Expert? Answer questions, earn points and help others
