Question about Dryers
I have a bosch classic xx condenser tumble dryer and it keeps stopping because the filter light is on. As soon as open the dryer and restart is works fine? Am I putting too much in?
  • hutchibe Apr 01, 2009
    Filter lights continuously comes on dryer stops working.
  • 750 Answers
Hi ya,
Welcome to fixya.
You have a bad filter sensor and or relay !
In a Bosch this is not a usual do it your selfer. You need a hands on experienced tech.
Please leave a solved rating before you sign off!
Huuum
Posted on Jan 23, 2009
Why when my door is open on my indesit idc75
The door switch is probably stuck in the "door closed" position. I presume the light inside also does not turn on.
Oct 05, 2014 | Dryers
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
Dec 21, 2013 | Siemens Dryers
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
My Bosch wtl6304 condenser tumble dryer keeps indicating empty filter light and bleeps rapid. It warns me twice like this then trips the thermostat out. I have cleaned filter, washed the condenser out and...
never really heard of a condenser model dryer before however it does seem like internally its full of lent inside of the dryer housing itself around the heating elements if you have a large air compressor open it all up and spray air into everything in the dryer where you see lent build up this will force any lent out of the dryer and it should hopefully run as the day you first got it ;P found this to be an issue even with an LG TROMM dryer i opened up and wasnt drying very well
May 06, 2017 | Bosch Axxis WTL 6307 Electric Dryer
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Bosch classixx tumble dryer container full light keeps coming on which is stopping the cycle but container is empty
This is happening me too. Have you had any suggestions how to solve this problem???
Nov 16, 2009 | Bosch Dryers
I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Sep 02, 2009 | Bosch Dryers
Bosch tumble dryer
I've sorted mine this morning. First, disconnect from the mains - VERY important! Pull out the metal condenser unit at the bottom, and behind it, there's a small hatch in the bottom to the reservoir. This can get gunked up with water, and is very difficult to clean - HOWEVER - I've found a really easy way of cleaning it. I've got a VAX carpet washer with a hose attachment, and I simply sucked all the water out using that. If you don't own a carpet cleaner maybe borrow one. I did this this morning, and my tumble-dryer's still running happily after an hour! It is possible to clean it out without vacuum, but it takes a LOT longer, and the vacuum of the cleaner pulls out gunk that is hard to access. Another place where gunk collects is behind that hatch right at the back - there's a tube up to the right. I pulled out quite a long chunk of lint. However, that wasn't the solution on it's own, I still had to clean out the reservoir as above.
Jul 03, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
482 people viewed this question
Top Dryers Experts
