Problem with the internal electrical transformer
I´ve got a split and the internal electrical transformer burned out, so I need to replace it. But I need info about type, resistance and capacity of it, for the 18,000 btu air split model.
Thank you.
P.S.: I am in Brasil, so if you have any distributor in here I´d like to know about.
  • 700 Answers
It is probebly a 50 va transformer 220volt or 115 if the inside is gas
Posted on Jan 23, 2009
How do I fix an ikea lamp with a burned out transformer.
go to an electrical whole sale business and see if there are transformers available that meet the specifications on the side of the original units and if so then consider getting them and have an accredited electrician change the plugs / sockets for transformers to burn out I suspect that the input voltage into the transformer is not as specified on the trans former and any transformers that you get will have to have the same primary voltage as wht is available at you place
Oct 30, 2015 | Computers & Internet
Find out the electronic circuit voltage
I am an electrical engineer and I do not fully understand your question. If the unit is designed to operate on 50/60 Hz, it cannot be damaged by operating it at either of those line frequencies. Mnay products today will operate at either line frequency.However, if you used an adjustable voltage power transformer (a.k.a. "Variac"), you may have "under-voltaged" or "over-voltaged" the device. If there is a circuit breaker, try resetting it. Otherwise, there may be a circuit board-mounted fuse internally that is now electrically "open." That can be tested with an Ohmmeter for continuity. (Finding a replacement may prove difficult.)
Operating a line-powered device above or below its input limitations can permanently damage internal power supply functions and, perhaps, other circuitry as well.
Solid state components can fail "open" or "shorted." If they fail "open" they will not draw appreciable current to "burn" them in any obvious way.
Nov 26, 2014 | Brookstone Pure Ion Advanced Air Purifier...
Fix power supply burned out transformer
test transformer for contunity if not ok ,then then replace internal termalfuse in transformer
Nov 13, 2013 | Bang and Olufsen Audio Players & Recorders
My thermostat keeps blowing itself out
Electrical problem getting to hot ie burning out stat check transforme rvolts ?
Jan 24, 2013 | Heating & Cooling
Wall oven bake element split
Was there a burning smell before at the time when it heated up slowly?A burning smell suggests there was a (possibly continuous) spark at the splitted place.If it was split earlier then the slower warming up was possibly due to a continuous spark, because then there won't be much energy left for heating.It's like an added resistance.So it could've been there for a while already.
The element just needs to connect again where it splitted and should stay there, then it should work again.
Jan 22, 2012 | Dryers
Turbochef tornado electric oven overheating and smoking one transformer is working fine but the new one is overheating
If transformer is looking burnt then replace it . It will show you F3 code once the transformer is. Totally burn. Tell me if you need help . I am tech for turbochef
Oct 14, 2011 | TurboChef TORNADO Electric Oven
No voltage from 24 volt transformer power in no power out .
The transformer is burnt out... you will need to replace it... this is common and they burn out easily if a low voltage wire it shorted even for a split second, or if there is a brown out...
They best way to prevent this is by installing a 5 amp fuse ahead of the transformer in the high voltage line so that it blows before the transformer goes...
heatman101
Sep 08, 2010 | Goodman CLQ36AR49 Air Conditioner
Split AC system not cooling.
P-7 Error Code means: DC Voltage Problem in the outdoor unit.
Bad PFC & IPM Circuit Boards.
The Pridiom Group
201-266-8234
Jul 26, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Marantz amplifier pm-34
the transformer has an internal thermal fuse. If you study the terminations coming out from the internals of the transformer you may notice either a pair of tinned thicker wires or insulated. This may be open circuit. I have often bypassed this internal fuse(they are notoriously common failures) to get a transformer going. You can get a replacement one from a parts supplier if you felt the need. I would just bypass it anyway.:)This may make the amp somewhat "illegal" in the US. We use the MEN (multiple earth neutral) mains power distribution in Australia and the transformer(if melting) would short out to earth and blow the mains primary fuse, the internal thermal is a US requirement.
Jan 12, 2008 | Audio Players & Recorders
Vibrating Noise and Electrical Smell
The noise and smell usually come from a bad transformer. If the magnetron has burned out usually the transformer will need to be replaced as well. The transformer is right behind the grille on the right hand side.
Mar 09, 2007 | LG 30" Over the Range Microwave Hood with...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
