Question about Bissell Cleanview Helix Vacuum
It sucks up the dirt and then rejects it. The helix part isn't spinning.
No suction
Check to see if you have a clog that is keeping it from sucking the dirt into the vacuum.
Jan 14, 2017 | Vacuums
How do I clean the filter
The foam filter can be hand washed, squeezed and them dried.
The pleated filter really never seems to loose it stall smell after cleaning. It's best to tap it against the hard ground to free the dirt.
Washing it can cause odors.
Sep 27, 2014 | Bissell 2 Sets Bagless Upright Vacuum...
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
My hoover savy U1825 isn't sucking in carpet mode
take the brushbar off and unblock the pipes they will be blocked with dirt and fluff
Nov 12, 2012 | Hoover Vacuums
The bottom of the vacum isn't sucking
My dyson animal seems to have a blockage in the base it makes I sucking noise then pops the sucks ion threw the wand is fine
Oct 22, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Brush doesnt turn
Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
this link is for the manual..
http://media.dyson.com/downloads/UK/floorcare/Manuals/DC24_allfloors_uk.pdf
Sep 23, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Its a reverse vacum, not sucking up anything just blowing it everywhere. The belt is fine and the filters are clean. Please help.
Hi r_holdsworth,
You got a deal! 2in1, blows and vacuums....
Actually, when vacuums blow instead of sucking, there is a clog somewhere. Usually, it's something that has been vacuumed up.
If you can't find the clog, please reply back with your model number and I'll find an exploded view of your machine for you to look at.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 20, 2011 | Bissell Cleanview Helix Vacuum
The vacuum was working fine then suddenly the main brissels that spin to collect the dirt stopped spinning, the vacuum still has suction but barely picks anything up because the brissels are not spinning
Best thing to do is remove the spinning brush and clean all debris from the brush and most importantly from the ends of the brush. The ends of the brush usually have two holders (square?) that hold the brush in place on the vacuum. The brush is supposed to spin in these holders. If it does not, provided the belt is okay, the location where the brush contacts these holders need to be cleaned and lubricated with some WD40 or some 3 In 1 oil. Be sure the belt is in proper running condition as well.
Sep 05, 2010 | Bissell Cleanview Helix Vacuum
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Bissell Cleanview Helix Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
