Question about Canon IXUS 860 IS Digital Camera
My canon IXUS 860 IS is having a lens error problem. firstly, the lens cant retract back and when i try to switch it on, the screen will say 'lens error, restart camera' so how do i restart the camera??
  • Canon Master
  • 4,738 Answers
Here are some troubleshooting steps for your lens error problem. And here's a video summary of those steps:
Posted on Jan 17, 2013
3 Suggested Answers
SOURCE:
SOURCE: lens error
Have same problem as above. Apparently the gears in the lense slip a tooth, they can be re-aligned but this involves taking out the barrel, my question is, how do you do this as I don't want to pay Canon the AU$250 for a new barrel.
Posted on Oct 15, 2009
  • 102366 Answers
SOURCE: lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
DISPLAY LCD~ Canon IXUS 860 ISWhat's your problem?
ldc as gone blank.can not see photos when i take a photo
Oct 28, 2012 | Canon IXUS 860 IS Digital Camera
The problem is that the camera cannot open the front eye, when you turn on the camera it does not come out. and at the end it say lens error, restart camera, but still do the same thing. help cause i want...
Its a common error with cameras with retractable lenses. It could be a grain of sand stuck in the slide parts of the lens. Another cause is accidentally pressing the ON button when the camera is in its case.
The solution is usually "helping" the camera lens to come out. This is a tricky job because it requires putting pressure (by pulling) on sensitive lens parts. If you're not comfortable with that, ask someone else to have a look at it.
I've had one IXUS 860 which could not be recovered from the lens error. The second IXUS 860 had the same error - the lens however moved finally after turning the cap for a bit. In the first case it was sand. In the second had tried to push the lens out while in its case - the ON button was pressed.
Jul 04, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Lens error, cannot focus, lens not retracting
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 21, 2010 | Canon IXUS 860 IS Digital Camera
Canon Ixus 860 lens
hi
If your lens comes out and retracs during power on or off then the spring that closes the lens is either broken or off trac. If you are within warranty period and able to open the case then it should be an easy fix. If not then you would have to get it repaired.
all the best.
thankyou.
May 05, 2009 | Canon IXUS 860 IS Digital Camera
Lens error with Canon ixus 970 IS
Has anyone responded to you on this yet - I have had the same problem and don't know what to do?>
Apr 07, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Lens error
Dec 14, 2008 | Canon IXUS V2 Digital Camera
Lens error
Oct 23, 2008 | Canon IXUS 860 IS Digital Camera
Canon IXUS 860 IS Digital Camera Logo
265 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
