Question about Asko W6021 Front Load Washer
Need information about an old ASKO 10604 washing machine
Please can you tell me what the following buttons do: one with two concentric circles and diagonal in across, green E button and 800 button. Also the items in the last wash came out cold, wonder if this is due to a cold rinse at the end of cycle 3 or might that indicate heating failure. Your advice welcomed!
  • metalmodels Feb 19, 2009
    Many thanks indeed, old Askos never die, they just keep going!
    Derek B.
Hi there, we have a 10505 machine and the controls must me pretty much the same. The green E is "Economy" button - increases main wash length by 22 minutes so you can use cooler water. The two circles with diagonal may be a spiral with diagonal if you look real close - this is "No spin" button - no spin in any cycle. The 800 button - when pressed reduces spins speed to 800 rpm from 1000 rpm. Not sure about cold clothes though. Do you have the hot water connected? Have you got a temperature dial? If so, make sure you dial up the required temp. Good luck!
Cheers, Brian.
Posted on Feb 19, 2009
Model W0611. How do I replace the door seal?
Hi John, the following YouTube video link may help, if this is not your model there is a further link in the video showing more ASKO machines, both links are shown below.
Trust this helps, regards Alan.
Washer Door Seal Replacement Asko Washing Machine Repair Part 8081128
Washing Machine Repair Help
Jun 08, 2015 | Asko Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Asko w6022 flooding root cause
Yes that can cause a flood.
Sep 19, 2017 | Washing Machines
During the washing circle the machine stops and F3 appears in the time window and machine cant restart
If F3 is flashing, then you are having a problem with drainage.
Check that there is no object stuck in the drain hose outlet. Check that the pump is not blocked by foreign objects and clean the pump. Check that there are no kinks in the drain hose.
After making these corrections, run the drain program or press the key button (door open) to empty the machine.
Feb 10, 2011 | Asko W6222 Top Load Washer
I notice there is an He Chlorox now that is advertised for the low suds washers...is this o.k. for my Asko 11505?
The He Bleach is sortof a marketing gimic. Its usally just a lower concentration of chorline. Since He washers use significtly less water during any section of the cycle Ie between 4-8 gallons some people can over concentrate bleach into water. As long as use follow the directions on your user manual for bleach and common residential kind is fine. I don't really recommend bleach tbh. Its corrsosive and and concentraion produces fumes which oxidize washers.
Jul 17, 2009 | Washing Machines
Wash temperature scale
TEMPERATURE - CELSIUS OR FARENHEIT
If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows:
Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
Sep 22, 2008 | Asko W640
Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Aug 27, 2008 | Asko W6761 Front Load Washer
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
ASKO Washing Machine WM220(ASKO 20605)-Control Panel
IS 2 looks like a MOSFET on my machine
I'm not sure on the Manufacturer - Their logo appears to be a large streaked "I"
The numbers on my mosfet read:-
H542
TOP200YAI (this last digit could also be a 1)
PC0288
Cheers from a fellow busted ASKO consumer.. :(
Mine appears to be motor or motor controller related, so if you don't fix yours, I'd be happy to take a few parts off your hands. ;)
Nov 06, 2007 | Televison & Video
Asko W6021 Front Load Washer Logo
179 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
