Question about Dell Inspiron 2200 Notebook
No bootable devices
My computer is powering up but it is saying no bootable devices...... what does that mean
  • cokebottle10 Jan 23, 2009
    so why it would not recognize the hard drive... is it that some part went bad?
    President:
  • 2,110 Answers
Go to BIOS MENU by pressing Del or F2 while booting...then check the boot priority and first boot device..change it to hard disk...if then same problem occur then your hard disk might have some problem...
Posted on Jan 23, 2009
  • Sibananda Jena
    Sibananda Jena Jan 23, 2009
    it might be the cable or the hard disk it self..
  • 70 Answers
It's mean
your computer cannot detect any bootable device
your computer cannot booting
have you install an operating system to your computer?
if yes
maybe your hdd is broken
or just it's boot sector
try to re-install your operating system
then
if your problem still exsisted
try re-install your computer with different hdd (i mean you need to replace it)
or
if the message appear when you try to install an operating system
maybe your operating system installer CD is broken or cannot be read
or your optical drive is broken
try to install with different CD
then if it just same
try to replace the optical disk drive
    Champion:
  • 203 Answers
The computer can't find the hard disk with instalation of windows, chek the hard disk to see if is properly conected on motherboard. or power conection on the hardisk.
  • 101 Answers
This means it is not recognizing your hard drive
4 Suggested Answers
  • 160 Answers
SOURCE: my computer says check cable connection
Check your bios and make sure that your boot from lan is disabled, and check the boot order. Make sure that your CD rom is first, then your hard drive, then boot from lan. Boot from lan needs to be one of the lasts you use if you use your laptop for personal use.
Also make sure any USB devices, like flash storage or external hard drives are disconnected from the computer.
Posted on May 03, 2011
SOURCE: my acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Posted on Jan 16, 2010
  • 1288 Answers
SOURCE: When I turn on my computer it's saying, no
First of all make sure you have not left a DVD in the drive or a USB device connected to the laptop.
If you have reboot, see if it works.
If there is no Bootable device in and you get the message again, enter the Bios and check if the hard drive is showing in there. If it is not, you have a problem with the hard drive and it will need replacing, sometimes, you can remove it and re-insert it and it will work ok.
If the hard drive is seen in the Bios, but will not boot, you should run the Windows recovery disc, let it find the previous version of wndows and attempt a repair
Posted on Jan 03, 2011
What do you do if no bootable device is found
When your pc starts as no bootable device that means it either can't see the hard drive or it's trying to start from the dvd or floppy? Do you know how to get into the bios menu?
Aug 23, 2014 | Compaq Computers & Internet
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Boot Cannot
This means your hard drive is not recognized. Most likely it is a failed hard drive. Another possibility is the power or data cable came disconnected from drive. This is only likely if your system has recently been opened up. A failed hard drive will mean a new hard drive will need to be installed.
Oct 25, 2013 | Computers & Internet
I was loading internet via a USB wifi stick and computer froze 1hr later I turned it off with power button. now computer says NO Bootable device. could this have been the USB WIFI to cause issue? Any...
Unplug all usb devices and restart your computer. If problem perursist re start your pc and press the f8 key and select HD.
no boot device means that your pc is not recognizing the hard drive and is trying to read the CD or your USB Device...tekgods
Sep 23, 2013 | Huawei USB-Stick 2 E160G 3G WIFI Modem...
No bootable device acer aspire 5250
This error message means that the computer is not seeing the hard drive or there is no operating system on the hard drive. In the bios does the computer see the hard drive? The unit may have to have the hard drive replaced.
Nov 05, 2012 | Acer Aspire 5250-Bz873 Amd Dual Core C-50...
Reboot and select proper boot device. what does it mean?
Boot device per see means that it is the device where you want your computer to start it may in the form of Optical drive (CD, DVD), Harddrive, USB drive (thumb drive), Floppy drive (for old computers). When get this error it also means that there are devices you have that are bootable it may be in a form of an Operating System Disk or just a simple bootable floppy drive. But the usual bootable device once you had the operating system installed already will be the Harddrive.
Apr 22, 2011 | Microsoft Windows XP Professional
My e-machine w3410 gives me a disk boot error insert disk and hit enter what does that mean
You probably have a non-bootable disc in the CD drive - when the computer powers up, your BIOS's first boot device is probably the CD drive and since it has a non-bootable disc in it, it can't boot. Remove the disc and re-boot your computer.
Dec 22, 2010 | E-Machines eMachines Desktop PC
When i try to power it on it says no bootable devices
Check the BIOS table and ensure the hard drive is listed. If it isn't, set the hard drive as the bootable device and if it won't reboot your computer, prepare for formatting and putting a new system on the drive as it is no longer initialised.
Dec 11, 2010 | Acer Aspire 5315 Notebook
My computer is telling me to check cable connection No bootable device-insert boot disk and press any key
that error message means that the computer cannot detect any bootable device(hard disk) try to check if you connect your hard disk properly
Nov 02, 2010 | Computers & Internet
My pavilion dv5000 says on startup media test failure check cable
Computers can start-up ("boot") from many different devices:
* 3.5" diskette,
* CD-ROM,
* USB memory-stick,
* disk-drive,
* network,
* external USB CD-ROM
and so on.
Your computer is trying to use the network adapter to download a bootable image through a connection with a network-cable to a "network-boot-server" computer.
In your case, "check cable" means that your computer's network-port is either *NOT* connected to a network, or that no "network-boot-server" responded to the request to download to your computer.
First, check the "boot-order", i.e., the priority of each of the bootable devices, to ensure that "boot from network" has a LOWER priority than booting from your diskette, your CD-ROM, and your disk-drive.
Second, check that your disk-drive *IS* one of the bootable devices.
Is there any bootable media in the diskette?
Is there any bootable disk in the CD-ROM?
If not, then your computer has *TRIED* and *FAILED* to boot from your disk-drive, and then tried and failed to boot from the network.
So, it's possible that your disk-drive has failed.
Take the computer to a qualified technician, and get them to remove the disk-drive from your computer, and to connect it to another computer, to see if the disk-drive still is in working-order.
Nov 05, 2009 | HP Pavilion dv5000t Notebook
Dell Inspiron 2200 Notebook Logo
2,230 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
