Question about Hotpoint First Edition FEW12 Front Load Washer
Hotpoint WM51 Washing Machine keeps tripping the electric
Any ideas what the fault might be?
  • 2 more comments
  • michele_hill Jan 23, 2009
    No, it was about half way through a rinse cycle when it tripped the main circuit board.
  • michele_hill Jan 26, 2009
    I plugged the washing machine in over the weekend, before I opened the door and switched it on at the socket, it tripped again.
  • michele_hill Jan 29, 2009
    Porblem solved, it was a spring that is attached to the drum that had broken and was earthing.
  • pedropony2 May 11, 2010
    Had it just started the wash when this happened?
  • 135 Answers
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Posted on Jan 23, 2009
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
HOTPOINT FIRST EDITION 800 WM51 USER MANUAL?
my hotpoint first edition 800 wm51 wont spin?
Nov 17, 2010 | Washing Machines
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Hotpoint washing machine model wm51 and the machine fills with water but stops and will not go into a wash cycle
could be heater fault listen to it if it works it should sound like a kettle warming
up it takes a while
Mar 02, 2010 | Washing Machines
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint 9537 washing machine tripping electric
You have a problem with Live feed shorting to earth on a main component. You need to switch off machine and seek a qualified electrician ASAP
Sep 03, 2009 | Washing Machines
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine tripping everything in the house
Washing machines take out ring main fuses if there are faults in the machine:
washers heater unit
motor
or suppressor.
Also water may have breached a seal somewhere and cause a short inside the electrical compartments.
To fix a fusing washing machine you have to use a diagnostic electrical meter that puts high voltage across the appliance - Not something I can offer more info on. So whatever has happened (and in the interest of safety) you would probably want a qualified proffessional to take a look or as a last resort a hotpoint engineer!
Feb 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
853 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
