Power surge to sanyo tv. can it be fixed?
A transformer blew and surged, and we lost 4 of our 7 LED TV's was wondering if these may be repaired. They do not turn on
  • 933 Answers
Most likely the power supply boards have been damaged. They can be repaired but I would highly recommend you take them to a shop and get them diagnosed
Posted on Jan 14, 2013
fieldy14
  • 456 Answers
SOURCE: Power surge, TV will not turn on
Power surges are extremely unpredictable, they can damage everything inside the tv, from the power supply printed circuit board, to the main printed circuit board. Normally the power supply takes alot of the damage from these things, so check over the power supply for any damaged components, any burnt out parts on printed circuit board, and also check the fuse. Good luck.
Posted on Aug 29, 2009
budmrtn
  • 11361 Answers
SOURCE: power surge hit my surge protector with my 'sony tv hooked to it.
Well, the power supply may be still damaged by the surge, what may happen is that when first surge happens the surge protector protect your TV by sacrifing itself but then the second surge comes along, since the protector already blown up then the surge will just come right through to the TV on the second surge. That is bad problem for the surge protector that sacrify itself but can only do it for ONE time.
Posted on Oct 31, 2009
  • 453 Answers
SOURCE: surge protecter says surge, tv has no power
not reset on this set , check power supply for bad capacitor on power supply
Posted on Apr 14, 2010
jdvillanueva
  • 2098 Answers
SOURCE: We had a storm come
Unplug your unit for 1 hour, before you power it on, press and hold the power button for 1 minute.
If the symptoms still there, then this is an indication that the power supply board was gone to malfunction. Some voltage surge protector is not a 100% reliable because it depends how high is the voltage surge coming from the source and if the design can handle such surged to avoid damaged to the unit. In your case, obviously the surge protector doesn't react efficiently.
Yes this kind of symptoms is quite fixable but needs to send it in because I've suspected that not only the power supply board was faulty but also the mainboard because your direct TV box was also fried which is connected to the TV.
Check if your unit is under warranty/extended warranty, avail it because the manufacturer will fix it for free, but of course don't mention that the unit was fried due to storm. If not, ask for an estimate first for service fee ($300 more or less depends upon the shop) plus parts to have an idea whether to send it in or buy a new TV.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jun 13, 2011
  • 411 Answers
SOURCE: I have a 47 inch sanyo. model# dp46848. A
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
Posted on Jul 06, 2011
My panasonic tc-p50x5 will not come on after power outage. whats wrong?
Being in the field of electronics I can not stress this enough....POWER SURGE PROTECTION...and I am not talking about a power strip with "surge protection"...they are useless. That being said you had a surge that most likely blew out your main power board. There is a fuse on that board and if you are lucky that popped and it is an easy fix. If not, you will have to remove the board, get the numbers on it and search out a replacement. There are plenty of places online to get them but I use Allied Electronics. One thing to check while you have the tv apart is to check all boards for visible burn marks or damage from the surge.
Feb 05, 2016 | Panasonic Televison & Video
Can a tv working normally after been stuck by lighting
In most cases no, depends on level of surge. I've seen cases where a surge came in through an HDMI cable and take out the HDMI port on a TV, everything else worked. I've seen cases where a surge damaged multiple boards on a set. So again it depends how how big of a surge, and whether the surge comes in through the power cable or an video/audio input.
Sep 07, 2012 | Toshiba 40WL753B Regza Wl 40 Inch Full Hd...
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
Jul 06, 2011 | Sanyo DP46848 LCD TV
I have a sanyo 26 " lcd hdtv and we had apower
hi you will need first to isolate where the problem might be so try to plug other unit or device in your power surge like a dvd player. if it is work your lcd tv have problem now how are you going to fix your tv, use a philip screw driver and open the back cover to gain access the internal part. since doesn't turn on check the power supply first which is the main source of supply of all the board. replace blown fuse and other defective part. bulged capacitor will not work good replace it use the panasonic brand atleast 105c ratings it is effective. thanks hope will help you to fix the problem.
Jun 19, 2011 | Sanyo Televison & Video
Had a power surge into the house- the tv was not on a surge protector and i am wondering if the tv is blown out- or is there a fuse possibly that blows at a power surge?
hello kath... if the tv won't come on now the power surge fried internal fuse and possibly more. The least expensive way to get this repair is to physically take the tv to the repair shop. If they have to make house calls, the cost goes up significantly. Joe
Apr 21, 2011 | RCA HD52W59 HDTV Projection Television
The problem started from a power surge.
You may be on the wrong track here.......fly backs are a common failure,but not because of power surge. Most commonly the problem would be on the primary side of the power supply ,such as the rectifiers and sw mode regulator. If you want to prove it,just un solder the horiz out transistor(q401) and the pin of the flybackit connects to...... and if it still blows fuse ,you need to work on the power supply.......not the horiz/hv area
Jun 04, 2010 | RCA F36665 36" TV
Panasonic 27 in TV
Power surges will attack every board in the unit, it is possible that they discovered that more boards were affected then could be changed for a reasonable cost. These tv's are not component level repair, but board level repair. There is no easy or good solution when a set has been severely damaged by a power surge. The best answer is usually to replace the tv. Also power surges are covered under most homeowners insurance.
Sep 05, 2009 | Sanyo DP26648 LCD TV
Power surge
maybe but more likely not if you replace these need to put surge suppressor on these line common occurrence happen alot and need to protect all electronics as well as computers
Jan 03, 2008 | RCA F32669 32" TV
Power surge
DONT BUY RCA AGAIN
..NO SERIOUSLY..I'VE REPLACED THE FLYBACK TRANSFORMER AND H.O.T. TRANSISTOR FOR MOST OF THESE PROBLEMS....NORMALLY A SURGE WILL TAKE OUT THE POWER SUPPLY...IN WHICH CASE THE BRIDGE DOIDE WILL BE SHORTED AND POSSIBLY THE TRANSFORMER....HOPE YOUR HELPED....MICHAEL SPARROW
Dec 28, 2007 | RCA 32V420T 32" TV
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
