My trane xr12 outside unit won't run - Heating & Cooling
lsteward68
  • 331 Answers
SOURCE: Trane XE 1200 ac The outside fan stopped
unless you have a meter youneed to see if the unit is asking the fan to turn on. if so the fan (which i doubt) maybe gone bad or the starting capasitor for the fan... is there anyway of checking the voltage to the fan
Posted on Jun 22, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Posted on Dec 30, 2009
SOURCE: I have a trane XR12
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Posted on Jul 29, 2010
Testimonial: "Thanks for your help and a quick response. The problem was the capacitor. $30.00 to fix the problem! You saved me a lot of time and money!"
hvac1960
  • 2133 Answers
SOURCE: I have a TRANE XR12
If a unit not operated for long time, chances to get rust over terminals and so power contacts will be poor. And also strcuk the compressor. No problem, by giving kick start by starting capacitor or power pack and also with new running capacitor, the compressor will start.
Better to call a repairman.
Posted on Jan 12, 2011
  • 1033 Answers
SOURCE: I have a Bryant Model
Hello, this could be either a bad capacitor or bad fan motor. If the fan starts by giving it a push then replace the capacitor, if it does not start the motor needs to be replaced.
Posted on Jul 07, 2011
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane xr12 heat pump switching to aux
Sounds like the compressor is not running. Possibly a bad capacitor. Check system in cooling, see if it cools. If it does cool then you likely have a reversing valve issue. Good Luck!!
Apr 30, 2017 | Heating & Cooling
Ac is set at 74 and it only cools to 80
system needs to be charged check filters and coils make sure they are clean first could be an air restriction issue to your intake
Jul 28, 2012 | Heating & Cooling
Trane xr12, fan works but compressor doesnt come on.
Check the capacitor and contactor. You may have wires burnt at the compressor terminal from corrosion.
Trane xr12 blower stays on after first cool cycle run
Hello, this is usually caused by a sticking fan relay on the intergrated comtrol board. You may be able to tap on it to shut it off but eventually the control board will need to be replaced.
Jun 02, 2012 | Heating & Cooling
I have a TRANE XR12 central AC UNIT, when i turn my thermostat on i get a click sound and ac unit does not come on. i checked the circuit breaker to make sure it's on.i have not turned this ac on for a...
There is a time delay on the stat to the AC unit, in addition the AC unit likely has one also, so immediate activation as desired isnt likely, however in 10 minutes of asking for AC if its not on still Id check the time delay fuses in the service disconnect at the AC unit, its a small grey box with the power cords running to and from it, there is 2 time delay fuses inside this box.
Jan 12, 2011 | Heating & Cooling
No heat on trane XR12 heat pump
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Dec 25, 2010 | Heating & Cooling
I have a trane XR12 Heat Pump. The cooling fan on the outdoor unit does not run nor does the compressor. The fan motor heats up and hums. I am guessing that the problem is the start capacitor on the fan...
Jul 29, 2010 | Heating & Cooling
Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Apr 28, 2009 | Heating & Cooling
Heating & Cooling Logo
282 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
