How do i format a new hard drive for my Bell 9241 pvr
5 Suggested Answers
  • 478 Answers
SOURCE: humax pvr can not read my maxtor 500gb harddrive why is that?
NTFS
1)allows access local to w2k w2k3 XP win NT4 with SP4 & later may get access for somefile.
2)Maximum size of partition is 2 Terabytes & more.
3)Maximum File size is upto 16TB.
4)File & folder Encryption is possible only in NTFS.
FAT 32
1)Fat 32 Allows access to win 95 98 win millenium win2k xp on local partition.
2)Maximum size of partition is upto 2 TB.
3)Maximum File size is upto 4 GB.
4)File & folder Encryption is not possible.
I hope this clears things up for you
Posted on Mar 08, 2010
citroenchris
  • 600 Answers
SOURCE: i have two iomega 500gb
If it shows on the desktop, go to utilities then disk utility and repair disk, also check as it may need formatting for the windows FAT format.
Posted on Feb 10, 2011
SOURCE: my harmony 600 wont control my Bell 9241 PVR
Your 9241 needs to be set to remote codes set #1 in order to work. The Harmony uses code set #1. You can do this by following the manual in the guide which comes with the unit. I don't remember exactly how to do it but it is in the manual. Once you change the remote code set to #1, the Harmony should work. I did this with a Harmony 300 and it worked flawlessly. QuintusPRE.
Posted on Apr 23, 2011
jonsnell4
  • 22132 Answers
SOURCE: Where can I buy a 9241 hard drive for a bell express PVR
Fleabay. 7results for bell 9241 hard drive
Any SATA2 hard drive will work.
Posted on Aug 23, 2017
Hi What partition file system does a HD PVR 2 P use to operated is it FAT 32 or NTFS
Your PVR will format a new drive. Go into the Hard Drive management section and there should be a "Format Drive" option.
Dec 06, 2016 | Computers & Internet
Bell satellite receiver model 9241 pvr function doesn't work
Hello, if you receiver is on rental I suggest to get a replacement from Bell it's free if it's still on warranty, otherwise here is what you should try, open the battery panel there are screw there you must take off, then slowly using a butter knife go around the remote to unsnap the two peace open, after it's open you need a Q-tip and some alcohol, dip the tip into alcohol and drip the extra of the q-tip with your two finger you don't wish too much alcohol, clean the inside of each button, it should look like little black round rubber, make sure to change your q-tip if it turn too dirty, after you clean all those button, gently clean the surface of the electronic part, don't use too much alcohol and don't push to ******* the electronic, you just need to take off the dirt and grease that might have accumulate there with time, let it dry few 1 min, then close and it should work like a new one, let me know :)
Jul 02, 2016 | Bell Televison & Video
How do I reconnect the WD harddrive to the Bell PVR with out losing what I have already transfer
It is very simple, just re-connect the device and restart the process for remaining data and simultaneously check if you have lost any data or not. If you have lost your data then you have to show your machine to an expert for Recovering Data from Hard Drive.visit us http://www.maidenheaddatarecovery.co.uk
Oct 24, 2014 | Western Digital WD Passport 250GB Portable...
Bell pvr 5900 won't work
I think you have the wrong category, unless it's a PC-Laptop?
Apr 07, 2013 | Computers & Internet
How to hook up to pvr
I imagine that the PVR does not recognize the formatting on the drive as it ships with the GUID partition scheme, and many of the PVRs probably need FAT32. Since the drive you have is 1TB, then you will need to use a Mac to re-format the drive as Windows can only format up to 32GB in FAT32. p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } To format the drive for cross-platform or PVR use, make sure that you have backed up all your data from the drive as formatting will destroy any data on the drive. First, connect the drive to your Mac, and open Disk Utility. Then select your drive on the left side of the window and choose the Partition Tab. Then change the Current Partition drop-down menu to 1 partition and click on the Options button. A new window will appear where you will choose Master Boot Record (MBR), then click OK. Then choose Free Space from the Format drop-down menu, click Apply, then OK. Your drive will now appear unformatted. Then choose the Erase tab, choose FAT32 as the Format, name your drive (you will be limited to 11 characters), and click Erase, then OK. Your drive will then appear on the desktop formatted for cross-platform use, and you can copy the data you need to move to your PC or PVR and then connect the drive to your PC or PVR. I hope this helps.
Apr 28, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My harmony 600 wont control my Bell 9241 PVR
Feb 12, 2011 | Logitech Harmony 600 Remote Control
Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Mar 05, 2010 | Denon AVR-1908
Bell pvr 9242 hard drive failure
YOU NEED TO TAKE IT OUT AND PUT IT IN AGAIN BUT MAKE SURE ITS IN RIGHT
Dec 30, 2009 | Televison & Video
Computers & Internet Logo
402 people viewed this question
David Payne
David Payne
