Question about Samsung Syncmaster 730B 17" Flat Panel LCD Monitor
Bought new HP computer and Samsung monitor. Everything plugged in OK but signal on monitor is CHECK SIGNAL CABLE. What is wrong - this is driving me crazy thanks
  • 1 more comment
  • Anonymous Feb 17, 2009
    My HP computer was working fine when all of a sudden the screen on the Samsung SyncMaster 731 monitor went black. I thought the problem was with the computer, but when I turned the computer off, the screen flashed Check Signal Cable. I hadn't changed anything. Same thing happened about six months ago, and thinking the computer was the problem, a friend cleared the computer and rebooted everything (I'm no computer techie, so I may be describing this incorrectly.) At that time, no "Check Signal Cable" sign came on, just the "analog, digital" square in the top left hand corner.
  • TechDuh Feb 17, 2009
    Several months ago, the monitor went black, but because the analog/ digital sign showed on the top left corner, I figured the computer was the problem, not the monitor, so someone cleared my computer and put all the programs back on. I've been using the computer since then, but today, the screen went black again. This time, after I turned the computer off, the monitor flashed the sign "Check signal cable." (I'm no tech person, so I may not have described this correctly.)
    Several months ago, my monitor went blank, but because the analog/digital sign still flashed in the upper left hand corner, I figured the computer, not the monitor, was the problem, so a friend reloaded all the programs on my computer. Today, the monitor went blank again, but this time when I turned off the computer, the monitor flashed the sign "Check signal cable." As far as I can tell, I hadn't changed anything, and the two cords from the monitor were still plugged in at both ends. (I'm no computer techie, as you can see from my name.)
  • 4,234 Answers
Typically this happens when the resolution of the display is out of range of the monitor. Normally this is when the resolution is too high. Have you changed the resolution settings? Also, not to be crass, but if there a video card in the system, be sure that you are connected to the correct VGA connector. With an extra card in the system, the onboard VGA connector is not used.
Keep us posted,
Posted on Jan 23, 2009
I have a Samsung SyncMaster 931c monitor and have just bought a new HP desktop computer. When connected, the monitor scans between digital and analog options, then nominates 'check signal cable' in...
Connect the monitor to the PC. Then, there is probably a button on the edge of the monitor that says AUTO. Push it once or twice when the PC is first turned on. First time that you get it to work, the monitor should remember. Good luck.
Dec 21, 2017 | Computers & Internet
I have bought a mew computer with a Sansung screem type LS19A300. It was working normaly and then a message "check signal cable" appeared. I checked all cables and nothing. So we changed the new...
Hi, what was the LCD displaying is that he is not sensing any signal from the computer video port that is why it is prompting "check signal cable". Have you tried checking the pins of your video cable from your LCD? if OK please plug in the cable again when your PC is already open to check that signal will pass thru and lets see what happen. If still the same, try to isolate it with laptop as external video if you have to check the LCD will work with other PC. If the same, replace the signal cable of your LCD if it is removable to further check the problem.
Jun 23, 2011 | Samsung SyncMaster 910T 19" LCD Monitor
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
I have a samsung 17'' lcd monitor.when i power on my monitor without data cable i got a message on screen CHECK SIGNAL CABLE.when i connect data cable my lcd is going to power off.please help?
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Oct 03, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
I have connected the display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Hanspree monitor says,''No signal input check video cable''
ask the shop for a replacement cable. it could be broken.
Mar 26, 2009 | Computers & Internet
Problems with digital cable
Check the source on the monitor, there's a button for it on the front.
Apr 10, 2008 | Samsung 206BW Monitor
New Monitor Installation
Does your computer have more than one video adapter installed. If so, try plugging into the other one.
Jan 13, 2008 | Samsung SyncMaster 216BW Monitor
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Logo
1,703 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
