Question about Garden
Troy-bilt storm 2840 snowblower leaking gas
Snowblower
  • 376 Answers
SOURCE: Just bought a 10 hp troy bilt chipper used. When
As LeeatCSEb said, It's your float needle and seat not shutting off the flow of gas when your carb bowl is full. Have your needle and seat replaced. Dwain
Posted on May 18, 2009
  • 5 Answers
SOURCE: finding a shredder screen for troy-bilt
Just found some parts for my Troybilt Gardenway chipper-vac Model 47279 on this website http://www.partsandservice.com/bin/ipl.cgi
I would think they might have something for your machine.
Posted on Oct 12, 2009
  • 389 Answers
SOURCE: My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Posted on Dec 19, 2009
  • 113 Answers
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Posted on Aug 18, 2010
SOURCE: need gas tank for troy bilt mdl#47287
I have one listed on ebay right now. Item # 190444315014
Thanks, Shane
Posted on Sep 20, 2010
Troy Bilt 3090 snowblower surges off choke, doesnt surge on choke, cleaned the carb, jets, float, drained tank, cleaned fuel filter, fresh gas, still surges. Could it be the governor or idle jet?l
you could try opening up the idle/mixture screw another turn to make the transmission from idle to throttle better
governors just open the throttle butterfly according to the spring tension setting from the throttle lever
Dec 16, 2016 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Only runs for a short time
Jeff, Try running with cap off for a short time to see if cap vents plugged, probable dirty carburetor.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Snowblower Starts Then Stalls
Tecumseh Carb snowblower cleaning 1 of 2
HOW TO Remove Clean Fixed JET on Snowblower Carburetor
Mar 23, 2016 | Toro 1028OXE Power Max 38663 2-stage...
My Troy bilt squall 2100 snowblower does not idle steady. It races and slows while idling.
It sounds like the carb needs cleaning and readjusting, or the fuel filter is clogged. Good-Day! Remove and clean out carb, it may be dirty inside.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Oil for a snapper snowblower 16223
I found the manual for you snowblower, and it's a two stage snowblower, so I am assuming you need two stage oil. Ultimately you need to get that information from the engine manual, and you haven't provided the engine information in you posting. This is the link for the blower manual:
http://dl.owneriq.net/1/121253fa-ec8b-4e20-b0b5-265321e0c7bf.pdf
Mar 01, 2014 | Snapper Garden
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
The ground broke off of the electric starter of my troy-bilt storm 2480 snow blower. Is there a way to fix it other than buying the $230 dollar replacement part?
You could just connect it as usual but provide a wire with an alligator clip on one end and the other end connected to the bare ground wires in the outlet box whenever you need to start the snowblower. An alternative ground location that is often easier for homeowners to access is to connect it to a cold water copper pipe, the external, visible ground point near the electric service, water main, cable TV, telephone, etc. Some states permit iron gas lines to serve as ground too. Check with your wiring inspector or local electrician to see what is acceptable in your town. Whichever way you choose to access ground, add this wire without disconnecting any of the others.
Once you have it wired up, the procedure is pretty simple really - you would first connect the alligator clip end of the ground wire to an unpainted, solid part of the snowblower's engine, starter motor or frame. Then plug in the power cord the way you did before the ground was broke off (orient the cord / plug as if the ground were still present). Press and hold the start button as usual until it starts. Once running, remove the 120 volt power cord first - then disconnect the grounded alligator clip. The ground clip must always be first on - last off. This way, at no time is the snowblower ungrounded when it is connected to 120 volts.
Of course, some folks will say you don't have to have a ground connected. True, it will work / start without the ground wire - but you do give up a bit of safety by ignoring it. The ground is to protect people from electrical faults - its presence does NOT effect the ability of the starter to function. I wouldn't dream of spending $230 to replace the starter just because it is missing ground wire (because it is so easy to get around the problem with my simple little fix) but I would only start it w/o the grounded alligator clip wire if I had too. For maximum protection, you should be connecting the snowblower to a ground fault protected outlet when using the electric start regardless of whether or not you're using the ground wire alligator clip.
Jan 07, 2014 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
