Question about Eiki EIP-2500 Multimedia Projector
My church has a EIP-2500 projector and it's not showing anything it just says no signal what seems to be wrong
3 Suggested Answers
homedesigner
  • 583 Answers
SOURCE: Remote won't turn on Eiki EIP-2500 projector
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Posted on Feb 08, 2010
SOURCE: No power to Eiki EIP-2500 projector
Look for buldging capacitors, or capacitors with black on the tops of them (like they got hot). Bad caps have left me dead in the water. Also look at all of your transistors (the ones with 3 prongs at the bottome (emitter collector base) look to see if some of them look burt or melted. Some transistors will have only 2 connected or maybe even one clipped off. Power transistors commonly have a screw at the top and screw into a "heat sink" or an aluminum block to help with heat. Hands down.... capacitors 9 out of 10 times have left me dead in the water. Heads up, capacitor manufactuers are manufacturing caps so that it's hard to see when the go bad, (buldge or blacken at the top). Looks like the old meausure voltage in parrallel and amperage in series will have to apply for these fixes. Get a schematic, change caps, check fuses for continuity. on my Eiki EIP-200 i notice a little buldging on C727 on my main power board (the board withthe Giant capacitor on it). Anything hot looking or burn marks, usually a replacment part is in store.
Posted on May 12, 2012
Where can I find a service manual for the Eiki EIP-2500?
difficult to find online, try comparable model of SHARP XG-MB55X
May 24, 2012 | Eiki EIP-2500 Multimedia Projector
How to remove top cover of Eiki EIP-2500 projector
loosen all the screws from the bottom ( one is in the middle) and two at the back ( edge)
press the grill on exhaust fans side near the heat warning mark.Lift carefully the rear and turn towards the lens side, BUT BE CAREFULL that some points of the upper cover will not scrape of some smd parts from the mainboard !!
Black line appear when start up
the connector between mainboard and DMD board should be clean.
even the pressure contacts between DMD and its boars should be spotless clean. takes experience to disassemle !!
May 02, 2012 | Eiki EIP-2500 Multimedia Projector
Is it possible to connect a projector and a flat-screen tv and control both with a laptop computer? (the flat screen would be used instead of a projection screen)
when connected at the same time, you need an active signal splitter, or
connect the flat screen to the monitor out terminal of the EIP-2500.
Apr 03, 2011 | Eiki EIP-2500 Multimedia Projector
Need a new remote control for a EIKI EIP1. How do I order one? I am in Perth Western Australia
Hello, I couldn't find any remotes available for this projector.
Try contacting Eiki directly with the form on the page below
Click here:http://www.eiki.com/ContactForm.aspx
Sep 20, 2010 | Eiki EIP-2500 Multimedia Projector
Feb 08, 2010 | Eiki EIP-2500 Multimedia Projector
How to set projector to project upside right instead of upside down from the ceiling mount.
press menu, go to scr-adj, down to prj mode, press enter, select front, and press enter.
Oct 11, 2009 | Eiki EIP-2500 Multimedia Projector
there is a fuse on the power supply. if the fuse is good, you'll need to replace the power supply.
Jun 22, 2009 | Eiki EIP-2500 Multimedia Projector
Eiki EIP-2500 Multimedia Projector Logo
16 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
