Question about Maytag Dryers
How do i open my maytag ld5004 dryer
How do i open my dryer
I have a maytag neptue dc dryer & I need to know how to replace the belt
open the cabinet:
http://www.partselect.com/dryer+maytag-atlantis-open-cabinet+repair.htm
route the belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 22, 2011 | Dryers
I have a Maytag Centennial gas dryer and the dryer will not turn off when the door is opened. I'm assuming this is due to a broken switch on the dryer door. How can I repair this?
door switch is correct you will need to unplug the dryer and open the cabinet open and replace switch, this website will assist you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
May 11, 2011 | Maytag Centennial 7.0 Cu. Ft. 6-Cycle...
How do i open the dryer to replace the belt?
use a putty knife slide it between the top and dorr panal
on each side you will feel a stop thats the "dog"
push it back with the putty knife
when both have been popped, the top will pop open
onecs inside you will see two 5/16 bolts holding the front on
2 things, remember how the tumbler sits on the back of the door, for reinstall
unplug before you open
once open it should be fairly easy
Oct 15, 2009 | Maytag PYE4558A Electric Dryer
How to open top of dryer
On most all Maytag dryers (true Maytag dryers, not Whilpools brand), you access the dryer from the rear panel, not the top.
Sep 30, 2009 | Maytag Dryers
I have a maytag neptune dryer. When I open the
Issue:
I have a maytag neptune dryer. When I open the door it doesn't turn on . What could be the problem?
Solution:
This is normal! The dryer has a door switch that will prevent it from operating with the door in the open position. This is a safety feature and cannot be overidden.
Aug 13, 2009 | Maytag Dryers
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
