Question about Kenmore Ovens
The oven goes straight to broil - Kenmore Ovens
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
Dont have oven service manual eb965611-01 to distinguish terminal lead hook up for broil element
unplug power. open oven door. unod screws holding element in place. pull straight to you. unplug and remember color cod to each terminal or place new element right under old one and replace it wire for wire. if not able to do that either write down or take photo of wiring.
Nov 22, 2014 | Ovens
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
Oven not heating- both baking and broil elements
It may be possible that the electronic control is bad. On some models there are three relays one for the bake and one for the broil and one for the common. This one goes out and the bake and broil will not work. The control is fairly expensive you may want to have a tech check it out.
Nov 10, 2013 | GE JTP15 Electric Single Oven
GE Double Oven Controller WB27T10276 Connection Details
I successfully replaced my WB27T10063 with the WB27T10276 (ERC3-GE-M) by following the instructions (Pub. No. 31-10515).
"they tell you for the Broil Relay to connect L1A to the common terminal."
This is simply a misreading of the poorly written instructions.
  1. Bake: yellow goes to yellow NO.
  2. Broil: violet goes to violet NO.
  3. Broil: black L1B goes to violet COM.
  4. AUX 2 goes to AUX2 (black and white wire).
  5. AUX1 goes to AUX1 (daisy-chained black from violet COM/L1B).
  6. OV2 goes to OV2 (white wire).
  7. OV1 goes to OV1 (brown wire).
  8. L1A goes to L1A (daisy-chained black from AUX1).
  9. N goes to N (daisy-chained white from OV2).
  10. GND needs to be "tucked under the (steel) clock bracket" on the control panel.
The hardest part was disconnecting the wires from the old ERC. Took a LOT of force! I also had a hard time figuring out how to release the green tape thing apparently labeled "J1" on the old ERC. Piece of cake after that.
Aug 09, 2012 | GE JKP27 Electric Double Oven
Neither the oven or broil element comes on. No error code appears, any thoughts?
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
Mar 02, 2010 | KitchenAid Ovens
Oven stays in warm up mode
does broil work? if broil works and bake does not you have a bad bake element. let me know how it goes
Jun 14, 2009 | Frigidaire Ovens
Whirlpool oven heating element
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Tried to use broil or bake on my Kenmore electic oven model 40881, press broil and after a few seconds a code of F4 comes on the screen and the tone sounds, I hit cancel and tone goes off. Can't use
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
