I have a Rheem Criterion gas furnace (model #RGDG125ARJR) with a working pilot light and fans, but the 5 heating elements won't fire up. What should I check?
5 Suggested Answers
james3751
  • 614 Answers
SOURCE: I have a Rheem gas furnace that shuts off
POssible feed back thru tstat. This sometimes happens. Take a look at tstat disconnect w or white wire that goes to heater. Turn from heat to cool and abck and see if it does it again if not change tstat. You can get a good one at Home depot or Lowes about 20.00 easy to install Keep in touch Rus
Posted on Nov 25, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Have a rheem criterion II. Model
The way it lights is that the gas is spread from one burner to the next by either a flame tray or small holes drilled in the burner tubes. If the flame does not get all the way across the burner tubes within a few seconds, the unit goes out on failure. Clean and inspect each burner tube, not just the orifice. Clean any tray that connects the burners. You can use a small wire brush or tooth brush but be careful near the glow igniter as it is very fragile.
Posted on Dec 12, 2009
  • 39 Answers
SOURCE: I have a Rheem Criterion II Gas Furnace that has
Turn off the power to furnace.
on the last burner to light there is a small metal rod in front of the burner. This is a safety called the flame sensor. It is dirty. Unscrew it from the bar ( 1 Screw) unplug the connector wire from it and clean it with steel wool. it will be kind of burnt. Plut back in place and turn on the furnace to cycle.
Posted on Apr 04, 2010
mxc2
  • 146 Answers
SOURCE: How do I get the covers back on my Rheem Criterion
Here is the manual for the furnace.
Make sure you do not have the panels mixed up..just saying it can happen.
Posted on Oct 24, 2011
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
Check air filter is clean , jump out pressure switch see if it lights
Jan 08, 2013 | Heating & Cooling
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
How do you lite the pilot lite on a Rheem Gas Furnace Model #rgma-125a
If I recall correctly, model number Rheem furnace you listed has electronic ignition to light the pilot, when the home's thermostat calls for heat. Is this what you're having a problem with?
Mar 11, 2011 | Heating & Cooling
Rheem furnace problem wont stay lit
You need to see what it does. Does it light at all? will the pilot stay on? If lights but wont let you release the knob then thermocouple is bad. I
If it is electric start then watch the series of events. enducer fan motor starts, element heats up, gas lights but shuts off after 1 second. 5 seconds 1 minute and so on. Also your computer board on the furnace will flash a code indicating a problem. count the flashes and read the panel on the furnace for help it should give a description of the the errors.
all depends on the age and type of unit. respond if you have more questions .
Feb 15, 2011 | Heating & Cooling
Rheem Model RGPS-12EARJR just purchased in Sept and now the furnace won't turn on. Can't find if there is a pilot light I should be starting, but even the fan doesn't go on - with or without heat
Newer, high efficiency furnaces have solid state controls and NO pilot light.
To light the gas the new furnaces use a ceramic heating element rather than a pilot light.
If the furnace isn't turning on you'll need to get a service tech to look at it for you. The circuit board has built-in diagnostics. Your furnace may have a window that lets you see the diagnostic light inside the blower box. Turn off the light in your furnace room to make it easier to see the flashing LED. See what pattern the light is flashing and look it up in your owners manual.
It's usually something simple, like no power (the light doesn't flash at all, obviously), or too much back-pressure on the exhaust line, or a faulty temperature sensor or faulty ceramic element.
I can't tell how you're trying to turn on the fan, but it could be as simple as a blown fuse or tripped circuit breaker.
There are just too many possibilities to make guesses.
Feb 01, 2011 | Heating & Cooling
I have a Rheem Criterion II Gas Furnace that has been acting up the last couple of days. It is model #RGPH-12EARJR. It will cycle on, ignite the pilot, 4 burners light and stay lit from 5-10 seconds then...
Apr 04, 2010 | Heating & Cooling
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
