Question about Sony MHC-GS300AV CD Shelf System
Display not working.
Hi all. I have had this hifi for around 3 years, went to turn it on the other day and the display isn't working. I checked the manual and noticed that the display has three cyclinic modes display, time and off so i checked all three modes and none show anything on the display. I then reset the unit as per the manual by unplugging, replugging and holding stop, clear and display. I am an electrical engineering student so i should be ok to fix the unit i was hoping for some insight into the problem and if anyone else has had a similar issue. Thanks in advance
    Problem Solver:
  • 9 Answers
This Problem needs an expert Technician: Your problem is due to a missing Voltage around -30 volts that supplies the screen Processor. It could be an open low value resistor or defective switching transistor. Good Luck Toufic Malek
Posted on Sep 25, 2007
SOURCE:
Display went dark/black- symptoms point to T-con board but after 20 minutes, display lit up for 2 minutes then went dark again. Same thing happened again after next 20. After 60, display stayed on
I was a Samsung tech for 3 years, and T-cons are a common problem. But it sounds like a loose wire to the T-con, I have came across the same issue in the field. I would break it apart and look for a loose connection.
Thanks,
Jason
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Jun 24, 2016 | Samsung UN39FH5000FXZA - 39in 1080p 240...
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
I have a whirlpool built in oven. Model RBD275PDQ8. The display (control panel) went blank 2 months ago. I reset the breaker, nothing. Pushed buttons, it just beeps. 3 days later I pushed the upper oven...
it's the control panel behind that touchpad item. and it's not too difficult, just time consuming. My recommend is to grab a service manual online(usually around 20.00) which will provide good step by step,and also parts list.
spares? well, that's a good question. Until you have that part number, and the best way is to eyeball the one that's in side your unit(no offense to the printers, but mistakes can happen with manuals).
then you'll find out what it's like to be truly handy, eh?
May 31, 2008 | Whirlpool Kitchen Ranges
GE Profile refrigerator pss26sgrcss isn't dispensing water, and 2 days control panel isn't working either. Not running and not cold at all, what are possible problems and solutions?
check for power at the display if power is present then you need a new interface (display) if no power is there then you need a new mother board located on the back of the unit square panel..mother board part#- WR55X10942--interface (display)-part#WR55X10390
Mar 27, 2012 | Refrigerators
I've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Feb 10, 2010 | Sony Electronics - Others
Kenwood XD V757 System Protected
check the speaker wires are not shorting out
Dec 11, 2008 | Audio Players & Recorders
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Display turned off, but i can make and receive calls
If you take the battery out then with the battery out plug in the charger, this worked for me.
Jun 15, 2007 | Motorola Mobility RAZR V3
Mhc-gnz88d (sony hifi DVD System)
5e592bd0-46d6-403f-ab4a-21969e3345d5.jpegI have a SONY MHC-GNZ88D Mini Hifi System. Everytime problem while play a CD or a DVD. The problem display "DESK ERROR". CD & DVD working but Next, Fwd, Stop etc buttons are not working.please help me.
My cont number - +91-9031257594 Nazish
May 21, 2007 | Sony Multi-System Mini Hifi Systems / DVD...
Sony MHC-GS300AV CD Shelf System Logo
340 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
