Question about Kitchen Appliances - Others
Logic L90sss11 steamer, keeps turning off during cooking period.
The unit is not in Holding Mode
My technika freestanding oven keeps turning off during cooking
if it turns back on by itself then it is working properly .
Jan 04, 2016 | Kitchen Appliances - Others
If you are mixing up different types of vegetables in a steamer, how do you know how long to cook it all for?
You have two choices when you are cooking several different types of foods in a steamer at the same time.
1. If you are cooking different vegetables, you can cut the harder ones ie potatoes and beetroot into smaller pieces than the softer vegetables.
2. You can open the steamer during the cooking process and add in the foods that need less time to cook.
A lot of it is about experimenting until you get the results you want.
Feb 18, 2013 | Home
Immediately turns to keepwarm mode after putting it on cooking mode
try to push the center button inside the cooker using anything not your hands.. then switch to cook mode, if the switch will not come back to warm mode then the problem is the spring on it.. you need to open the cooker and try to remove the spring then stretch it..
Sep 06, 2010 | Panasonic SR-42F 23-Cup Rice Cooker
Steamer switches on off on during cooking process
Hi Markus, did you manage to solve your problem somehow? I experience the same (with the same steamer).Thanks.Tomas
tondrejcak@yahoo.com
Mar 31, 2010 | Kitchen Appliances - Others
Sensor problem turning off during cooking
If this is a new rice cooker first try cleaning the thermal sensing unit by scrubbing any build up with a green brillo like scrubber, also clean the bottom of the rice pot where it contacts the thermal sensing unit.
If this doesn't work and your rice cooker is 1 to 2 years old replace the thermal sensing unit.
Jan 19, 2010 | Rinnai RER-55AS 55-Cup Rice Cooker
Rice cooker goes to "keep warm" mode before rice is cooked
bad thermostat . there are no parts made for this model . sorry
Jan 17, 2009 | Tiger JNP-1000 5.5-Cup Rice Cooker
Rice cooker unit does not turn on after ading rice and water.
This unit has had many recalls. Oster got a bad unit and is telling customers to return for free replacement. The 3072 model has a bad computer board. Take it back for free replacement.
Dec 14, 2008 | Oster 3072 20-Cup Rice Cooker
Rice Cooker promaturely pops up before rice is cooked
try adding a little less water, And letting it sit about 4 min to make sure the steaming has stopped
Oct 21, 2008 | Zojirushi NRC-15 8-Cup Rice Cooker
Will not turn off
there is a parts list on the wed , there should be a temp sensor inside that shuts the gas off when its finished cooking , it might be cheaper just to buy a new one ?
Oct 23, 2007 | Rinnai RER-55AS 55-Cup Rice Cooker
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
