Bosh WFP 3300 HydroSensor keep blowing up fuses
My Bosch keep blowing fuses after few minutes of the main wash.
When I switch power back and skip main wash step all other following program steps work correctly.Any idea why it happening or witch elements i should check or replace?
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
How to use the delay timer on my washing machine
Each time you press it it changes the amount of time before the chosen program will be finished
eg 4hr means in 4 hours the cycle will finish
Sep 27, 2014 | Bosch Washing Machines
Bosch nexxt 500 series dryer how to reset
Turn off the main breaker for a few minutes then turn it back on.
May 23, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
No lights on bosch washing washer
check to see if there is any power going to the main board and if not you have a problem with a plugin, but if power going to main board then you have a fuse blowed, ie ceramic fuse.
May 05, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Bosh Axxis WFL 2060 operates only on quick wash and warm water!
If you cannot switch cycles then the selector switch board or main circuit board can have faulty componenents and will need to be tested with a multi-tester
Jun 03, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Our Bosch Maxx 7 skips spin cycle of the washing program. The remaining time jump from about 7 minutes to 2 minutes
Possible that the program controller unit has some errors and so it does work erratically. Check on all connections to the program controller unit, check for moisture on the unit. Also remove power for few hours and see if there is any on : washing machine tips
Mar 14, 2012 | Bosch Washing Machines
No power to machine. power socket is live as i have plugged in another appliance which works. does the machine have fuses?
Sounds like you need to have the mains suppressor checked out by an engineer.
Someone had this happen to them as well.
I checked fuses - ok I drained detergent water -ok I checked filter and pump - ok Machine will not start. Next step - contact customer service, however under the Sales of Goods Act 1979 I am contacting the supplier as the machine is new.
I hope you get your machine running soon.
Update The fault was as follows: Bosh Washing Machine WAE2446 Fault reported: DEAD Material: SUPPRESSOR Description: REPLACED FAULTY MAINS SUPPRESSOR
In a nut shell. The washing machine failed (went dead) because the mains suppressor was faulty. The suppressor normally filters out unwanted interference from the washing machine mains electrical supply. The part was replaced and the washing machine came back to life.
Mar 18, 2011 | Bosch Washing Machines
Plastic rectangle part of the door lock of bosch wfp 3300 is broken
that whole piece is part of a switch. you must take off the front panel to fix. not a easyfix if you dont know how.
Feb 26, 2010 | Bosch WFMC 3200 Front Load Washer
Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Feb 27, 2008 | Washing Machines
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
