Question about Nokia 6600
Nokia 6600 power switch destroyed
My nokia 6600 power switch destroyed. i contacted some experts to replace it. they told me to direct the power switch jumpers.is there any solder solutions direct power on nokia 6600 please reply your solutions to me.
regards,
harikrishna
  • deekom5 Apr 13, 2009
    Nokia 6600 power switch destroyed. is there a code to put it on?
5 Suggested Answers
patel352003
  • 192 Answers
SOURCE: nokia 6600 won't turn on
Sometimes this occures after flashing. It seems you flashed it with older version files. Try to reflash it with higher version and it will be OK. Other thing is that if your bluetooth module is defective then flashing can be lead your phone to this status because bluetooth is always stays in system start-up. If it is so you have to try reflash it with disable blutooth flash. If it is not solving your problem then mail here including the details bellow:
1 Which software you are using? UFS, JAF or any other?
2 Are you skilled hardware technician? Can you understand the
circuitry diagram and hardware tricks? as it was provided from
here.
Posted on Jan 13, 2008
SOURCE: nokia 6600 joystick
dump the phone, it is waste phone, full of problem
Posted on Mar 19, 2008
indiandevil
  • 110 Answers
SOURCE: latest nokia 6600 software version
TRY HTTP://PUNJABIMOBI.COM
Posted on Jul 27, 2008
SOURCE: power switch connection
sir' my nokia 6070 on/off switch is destroyed.could you plz show me how make a jumper to restore the track.
Posted on Oct 04, 2010
SOURCE: 6600 power switch jumper
how can i repair my 6600 without the 2 capasitor frome the swits plssssss. help me
Posted on Mar 29, 2011
My nokia 6600 switch on button is not working.....what i have to da to switch on my phone....
Possible that the power ON switch is gone weak and is not contacting. You can open to get access to the switch and try to short the swtich momentarily so that the phone turns ON. If this works then the phone switch is faulty and must be replaced.
If not you must check with the battery voltage or take opinions.
Jun 16, 2011 | Nokia 6600
here buddy
hope it helps...
Jun 03, 2011 | Nokia 6600
how to have cellphone
Oct 25, 2010 | Nokia 6600
Nokia 6600 startup failure
I have the 6600, last week the mobile couldnt work. phone registration failed contact retailer message displays. i have many messages in that mobile. i contacted the retailer, but the retailer told only solution is flashing the mobile. shall i get back my messages in that mobiles please help me
Jan 05, 2010 | Nokia 6600
How can i format my nokia 6600 direct
Formatting on your 6600! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6600 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 6600 will back to original system and factory setting.
May 27, 2009 | Samsung SGH-D500 Cellular Phone
Power switch connection
Jan 14, 2009 | Nokia 6070 Cellular Phone
Nokia 6600 "no charging"
Even if you think that the battery and adapter are good, test the battery on a different phone, and test a new charger on this one.
If you get the problem with a different charger, then replace the AC socket on the phone, as already suggested by the other expert.
This job must be done by somebody that knows very well how to do precision soldering, therefore is not a task for a neofite repairer.
Here in UK an AC socket replacement can be performed at any phone repair shop for a small fee.
Nov 23, 2008 | Nokia 6600
Hi to all
switch off your phone
then press * 3 & green button then press power switch to power on your phone
dont leave buttons until formatting started
but after that you will lose your all phone memory data .
good luck
Jul 29, 2008 | Nokia 6600
How to remove bluetooth from nokia mother board for 6600
you need the following
tools and material
Need a Hot air device'
twezzer'
flux
dismantle the unit and put the flux around the bluetooth,
re-heat the bluetooth w/ the hot air device or a infared soldering device' wait unti the solder led around the bluetooth is soldered...
Jan 23, 2008 | Nokia 6600
Nokia 6600 joystick
make a jumper w/ a jumper wire joystick #4 to flex #4
skilled technician can performed the jumper'
or replace it w/ new keypad joystick of 66..00
Oct 21, 2007 | Nokia 6600
Nokia 6600 Logo
175 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
