Question about Garmin Oregon 450 Handheld GPS Receiver
DISPLAY BACKLIGHT PROBLEM - Garmin Oregon 450 Handheld GPS Receiver
    New Friend:
  • 22 Answers
Hold the power button after the GPS has started up and you will get a screen where you can set the brilliance.
Posted on Jul 28, 2016
Display and backlight using my battery up how do I fix this?
The display and backlight are the biggest users of power for any computing device. You can lower the display brightness and on some even lower the backlight intensity to conserve power, but this will have an impact on your viewability.
Sep 18, 2016 | Tablets & eReaders
My lcd display is dim on my sony xdr-ds12ip dab radio, you can see the display faintly and it does search and display the time. Also the backlight is working normally.
The backlight allows you to see the display. The LCD display only allows the backlight to shine through and produce the characters. Try looking at the display from a different angle as the light is polarized.
Jan 29, 2015 | Sony Computers & Internet
How do I fix the backlight of my garmin 3205
The LCD display contains both the display and backlight. They are integrated as one piece. Therefore the entire display needs to be replaced. The backlight connections are soldered to the LCD connections. Replace the entire display.
Dec 25, 2014 | Garmin nuvi GPS
Laptop display backlight turns off
check and change the display inverter. backlight problems are related to invereter.
May 11, 2013 | Toshiba Qosmio Computers & Internet
I have a uniden bc340crs scanner that is 1 yr old. my backlit window does not display any of the info for my scanner. i want to reprogram and the 2-9-hold thing does not work even after trying ronnie...
This is how you control the back light display on your scanner.
SNOOZE/Backlight - Backlight: Tap the snooze button to turn the LCD backlight on for 15 seconds. Press and hold to permanently turn on the backlight. Press and hold again to turn off the backlight.
Here is a link to the users manual as well. http://www.uniden.com/pdf/bc340crsom.pdf
Mar 14, 2011 | Uniden BC340CRS Base Scanner
I changed the batterys in my 1F78-151 thermostat and now the backlite does not work.....
• Display Backlight - (Not available on earlier models.) The display backlight improves display contrast in low lighting conditions. Selecting backlight ON will turn the light on for a short period of time after any button is pressed. Selecting backlight OFF (default) will keep the light off. Turn the display backlight feature ON as follows: 1. Press TIME and RUN buttons at the same time. The display will show "d-L" and "OFF" alternately
Dec 22, 2010 | Heating & Cooling
My sansa clip will play music but the screen will not light up;
There's a timer for the display backlight that can be set and used for
saving power. When leaving the player untouched for a certain time, the backlight switches off. Touching any button will turn on the backlight, restarting the timer.
To set the backlight timer on the Sansa Clip,
execute the following steps:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
Camera turns on fine. I could view picture and all. Just that when I switch to camera mode a video screen is blacked out. Why is that?
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
Sep 04, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
The wired keyboard backlight turnes off too quickly
You would need to go into the Setting Menu and find the Backlight or Power setting to lengthen the display and keypad backlight times. Just know that your battery life will decrease the higher the settings especially since it is a VGA screen.
Dec 18, 2008 | HTC Touch Pro Smartphone
Beoken backlight
u kant
u will have to get another screen 4 ur psp
Nov 18, 2008 | Sony ACY-BR81/OB
Garmin Oregon 450 Handheld GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
