Question about Reebok Exercise & Fitness
I HAVE A REEBOK Z9RUN TREADMILL WHERE DO I OIL IT
SOURCE: Need a Reebok treadmill repairman.
I can fix it for you. Just post it to me in London. Hope this was of help!
Posted on Mar 02, 2009
SOURCE: I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Posted on May 18, 2009
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
greenspan
  • 1734 Answers
SOURCE: I have just bought a Reebok 3 series treadmill.Do
If manufacturer and google are of no help, ask them. They already found some hard to find Reebok manuals. I guess they have the TR3 for download on their site.
Posted on Aug 23, 2009
Reebok v8.9 treadmill
you must LUBE the deck belt INMEDIATELY, however this indication is the lack of maintenance, probably your have a worn deck, see the diagram attached, and take action.
God bless you
Jul 22, 2012 | Reebok Exercise & Fitness
I have a reebok rev 11301 treadmill the oil light has come on but i dont have my manual and i dont know were the oil goes
just pick the rubber belt (on which you run) and put oil under it 1Ml on front left and 1ML on front right
Nov 12, 2010 | Reebok New York Giants Eli Manning Jersey
I have Reebok treadmill T5.7 , i found LED indicator for oil is red How can i solve it?
Their is no LED indicator for oil in any treadmills. The upper console in some models will give a prompt to lubricate the the deck. IN upper end units if this not done in a promptly manner the unit will shut down until lubrication procedure is completed and the unit is reset per owner's manual.
Go to jadfitness.com they will Lube kits with instruction on how to clean and maintain the treadmill
Jul 19, 2010 | Reebok Vista Treadmill - RBTL13305
How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Mar 07, 2010 | Reebok Exercise & Fitness
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
Where can i get a reebok TR3 treadmill user manual
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Oct 25, 2009 | Reebok Rt1000 Treadmill Walking Belt
Oil can caption on my reebok fusion treadmill (rev10301)
It means that you need to spray silicone between the belt and the platform it runs on
Jan 10, 2009 | Reebok New York Giants Eli Manning Jersey
4. Press Speed up
Dec 02, 2008 | Exercise & Fitness
Exercise & Fitness Logo
77 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
