Question about Panasonic PV-GS150 Mini DV Digital Camcorder
Will not turn on?
I have the same problem, my PV-GS 150 will not turn on? I plugged it into the wall thinking it was just a dead battery but it still won't turn on. It just makes a small clicking sound from within the camera. When I open the Mini DV casset holder the casset doesn't even pop out. Any Ideas? What did you do to fix this problem? Thanks for the help JEFF
  • mike j Jul 14, 2008
    ive charged the battery and plugged directly into adapter both ideas didnt work. ive tested the terminals on the adapter and got proper voltage reading, no positive effect.
  • Anonymous Aug 05, 2008
    My panasonic camera will not turn on. I tried charging the battery and using the plug in battery but no results, but no results.
    Champion:
  • 217 Answers
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 18, 2007
SOURCE:
I have a 1988 f150 XLT larriat when I turn the key it does nothing I have no power to lights radio windows nothing battery is good replaced ignition actuator (white box on steering Column) checked fus
will a known good device plugged into cigarette plug work ? if not then the fuse link located next to starter solinoid on passenger side engine wall is bad a simple 12 volt light bulb will confirm that ,if it Lights on one side and won't light on other side (ground one side of light bulb)
OOhh no light on both sides your battery is dead or loose
Oct 05, 2012 | 1989 Ford F 150
DEAD. MAYBE INTERNAL BATTERY IS DEAD? DONT THINK ITS THE WALL CHARGER...WUT CAN IT BE???
Wall charger's go bad. Measure it's output with a volt-meter, to make sure it's working. I killed one watching too many dvds on the computer and overworking it.
Mar 21, 2010 | Toshiba Satellite A135-S4527 Notebook
My pv-gs180 camcorder wont power up. I have
Remove battery plug it into power (charger block) then do reset.
Oct 12, 2009 | Panasonic PV-GS180 Mini DV Digital...
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
My zen jukebox turns off then on and I just replaced and charged a new battery
Take out the battery. Plug it in. Does it play reliably?
Yes: That's a bad battery.
No: reset the device, and try above again.
Aug 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
PV-GS 39
Go to the canadian web site and download the driver for the GS-39 there. It worked for me with XT.
Dec 24, 2007 | Panasonic PV-GS39 Mini DV Digital...
Battery problems
Sounds like the battery is shot. Does the camcorder work ok on the AC cord?
Oct 20, 2007 | Panasonic PV-GS39 Mini DV Digital...
Panasonic PV GS 150 Won't turn on.
this is the problem of this unit. it's probably the motherboard. because we have the same problem in my mini-dv
Feb 22, 2007 | Panasonic PV-GS150 Mini DV Digital...
Panasonic PV-GS150 Mini DV Digital Camcorder Logo
153 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
