Question about Shimano Cycling
Chain tightening on hyper havoc fs - Shimano Cycling
26" Hyper Havoc Full Suspension Men's Mountain Bike is it good ride for around town as well as country terrain
Looks like a nice bike to ride everywhere and as an urban commuter I would love to ride it in traffic instead of using a road bike or commuter type. If you need more speed in town or want to compete, a road bike might be better. A mountain bike will probably last longer than a road bike under all driving conditions.
Feb 21, 2016 | Cycling
After you install bar,chain,and brake cover(tightened)the chain wont turn.
Tighten the adjusting screw with the two nuts loose but snugon the middle of the chain on the top of the bar. Tighten the chain screw until the chain is loose enough to raise the chain up about 1/2 inch then tighten the mounting nuts tight. Then see if it is ok.
Terry
Jan 07, 2015 | Husqvarna 338xpt 14" Gas Chain Saw Husky...
Plastic chain cover is cracked
Remove cover lightly sand then put some ultra blue silicone let dry over nite . U can get it at WalMart or auto parts stor
Jun 02, 2014 | Hyper Bicycles Hyper Static 20" BMX Bike
How do you fix the chain
Remove cover on the chain side of the saw. Loosen the two hex nuts that hold the bar onto the saw. You will need to loosen the tightener screw also. Place chain back onto the bar making sure the chain is positioned properly in the sprocket at the rear of the bar and just reverse the directions. Tighten the tightener screw until the chain is tightened leaving a little slack, then tighten the two hex nut. Replace the side cover. When you pull the chain down away from the bar, it should have just a bit of slack not tight. This allows the chain to turn without a lot of friction. I hope this helps.
Jan 26, 2014 | Homelite Garden
1996 gmc c 1500 won't start back fired & died & red light us on on my hyper teck power tuner
Sounds like your timing chain has jumped out of time, if the timing chain is old, the chain jump a few teeth putting it out of time having it fire at the wrong time when the exhaust valve is open. Check timing by pulling #1 plug - bring #1 piston to the top and line up timing mark , Ifind it easy to put thumb over spark plug hole and have someone bump the engine over and feel the pressure relief stop before you feel vacumm - timing mark should line up if the timing hasn't jumped
Mar 03, 2013 | GMC C1500 Cars & Trucks
Chain dowsn't stay tight
Between the chain bar and the body there is an adjusting screw, if the adjusting screw is stripped it will not pull on the chain bar to tighten the chain.
procedure for tightening chain. loosen the chain guard nuts, tighten the bar adjusting screw by turning to the right or clockwise, the chain has to roll freely around the bar but not bind. check with gloves or rag, don't use bare hands to avoid accidents. once chain is adjusted, tighten the chain guard nuts. good luck!
Oct 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Unable to tighten chain .. too droopy.
There are usually two 7/16" nuts on the side of the chain saw. Loosen those a little first, then turn the screw to tighten the chain - not too tight or you'll stretch out the chain when you use it. Don't forget to re-tighten the two nuts before using the chainsaw.
May 16, 2009 | Remington Electric Chain Saw
Chain check and maintenance
Depending on how aggressively you ride, chains should be inspected every 500-700 miles, or roughly twice a month
Nov 10, 2008 | 1982 Suzuki GSX 400 FS impulse
Oil leakage from engine.
Check if oil drain bolt is tightened properly. Check for gaskets wearout if so visit the nearest Authorised Service Station. Oil leakage could be from chain drive if excess lubrication is done.,
Nov 10, 2008 | 2008 Husaberg FS 450 e
Chain
Put it up on your stand lossen the axel and remove the bolt on the bottom of the shock. Then tighten your chain and lift your swingarm up until its horizontal with the ground, then the chain should have almost no play. Not completely tight, but almost no play. Tighten the axel, and the bolt on the shock, and your set,,,
Nov 10, 2008 | 2005 Husaberg FS 450 e
Cycling Logo
207 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
