Question about Frigidaire Refrigerators
Frigidaire model LGH2342LF2 refrig displays SY for freezer temp and EF for refrig temp. What do these codes mean?
Regrig and freezer temps are set at 37 F and 0 F. The readout says EF and SY. What do I need to do? Cecil Clements
aasc
  • 1606 Answers
SOURCE: Freezer set to 0 actual temp - 1
Set the refrig temp to 42 degrees . Also check to see if the damper (top left in refrig section ) is closing to stop the air flow into the fridge section . Sometimes they will stick due to ice build up inside the damper . Sometimes also , putting a knife inside and wiggling it around , will break it free , however , it may have to be replaced along with the #1 thermistor .
Posted on Aug 09, 2009
iwillfixforu
  • 619 Answers
SOURCE: Model 106 56569400 - Freeze side appears to be Ok.
If you have heavy frost build up on the back wall of your freezer you have a defrost problem. One of three things. Defrost timer, Defrost T-stat or Defrost heater. Usually problem is with the T-stat. If no frost make sure the evap fan is blowing. You should be able to hear a fan noise when opening freezer. If no fan noise replace evap fan which is located half way up behind freezer wall. Good Luck
Posted on Jan 27, 2010
heatman101
  • 43501 Answers
SOURCE: Refrig is freezing foods and will not stay set at temp recom.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
woodchuck789
  • 4070 Answers
SOURCE: power to refrig. Front displays
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Aug 04, 2010
ZJLimited
  • 17970 Answers
SOURCE: On the freezer and fridge
There is either something wrong with the fan or the computer. But the only thing you can do is go through the owners manual if you can't correct it with that you will have to call for warranty service. If you go any further then that you will void the warranty.
The short answer is that EF on the Electrolux refrigerator digital display means "evaporator fan." The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Hope helps.
Posted on Apr 07, 2011
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Temp display on door is giving wrong display
this is a fault code.. take a picture of the panel and post it here also picture of the model and serial tag.....I can find the fault codes with the info asked for............ ken
Sep 30, 2014 | Refrigerators
What is code 5y and ef
Hi M - I am happy to assist you! Error codes SY/EF is commonly refer to a failure with the evaporator fan circuit. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, then more than likely there is a potential wiring failure between the main control board and evaporator fan. In this regard, I would personally suggest to reaching out to a repair tech to further evaluate and repair you appliance. If you have further questions, please do not hesitate to reconnect.
Jul 18, 2013 | Frigidaire FRS26H5AS Side by Side...
Frigidare gallery model LGHS2665KFO
My Refrigerator will beep and sometimes put a code SY where the freezer temp shows. If we unplug it and plug back up it works, but every few hours it beeps. I cannot find my book on it to see what this means.
Feb 17, 2013 | Frigidaire Refrigerators
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
On the freezer and fridge temp display there are the codes SY and EF. My manual doesnt give any trouble codes.
Hope helps.
Apr 07, 2011 | Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Refrigerators Logo
89 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
