Question about Canon IXUS 860 IS Digital Camera
Solutions for "lens error restart camera canon ixus 860 digital"
  • Canon Master
  • 4,738 Answers
Posted on Jan 16, 2013
wipdhuls
  • 133 Answers
SOURCE: len error restart camera canon IXUS 80 IS
Its also known as E18 error and you would be surprised to see how this issue is resolved .. check the fallowing link:
http://www.e18error.com/posts/index.php
Posted on Apr 02, 2009
parjee
  • 83 Answers
SOURCE: how to fix digital camera canon ixus 70 'lens
Would not recommend opening the camera as the chances are much greater for you causing greater damage. BUT would instead recommend that you try the seven sequential repair step outlined for a lens error in the below listed Related Link "Fixing a Lens Error on a Digital Camera". None of the steps outlined in this link involve opening the camera. and reportedly you should have close to a 50% chance of success with these techniques.
If you cannot repair the lens yourself with the first related link, then consider trying the two 'Digital camera repair" links below for two online digital camera repair businesses.
Posted on Sep 22, 2009
SOURCE: lens error
Have same problem as above. Apparently the gears in the lense slip a tooth, they can be re-aligned but this involves taking out the barrel, my question is, how do you do this as I don't want to pay Canon the AU$250 for a new barrel.
Posted on Oct 15, 2009
t00nz
  • 4738 Answers
SOURCE: Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Mar 20, 2010
  • 420 Answers
SOURCE: Canon Ixus 900 Ti ~ Lens error Restart camera
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
Lens error restart camera
Here are some troubleshooting steps that you can try that may correct your problem. If the camera is out of warranty (or repair cost approaches that of the camera), they're worth a try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
And here's a video summary of the steps:
Jul 16, 2013 | Canon IXUS 860 IS Digital Camera
I have a canon powershot sd1200 is camera and it says lens error, restart. I have tried restarting and it continues saying the same thing
Copy and paste this website into your browser for solutions:
Nov 12, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
The problem is that the camera cannot open the front eye, when you turn on the camera it does not come out. and at the end it say lens error, restart camera, but still do the same thing. help cause i want...
Its a common error with cameras with retractable lenses. It could be a grain of sand stuck in the slide parts of the lens. Another cause is accidentally pressing the ON button when the camera is in its case.
The solution is usually "helping" the camera lens to come out. This is a tricky job because it requires putting pressure (by pulling) on sensitive lens parts. If you're not comfortable with that, ask someone else to have a look at it.
I've had one IXUS 860 which could not be recovered from the lens error. The second IXUS 860 had the same error - the lens however moved finally after turning the cap for a bit. In the first case it was sand. In the second had tried to push the lens out while in its case - the ON button was pressed.
Jul 04, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Oct 08, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Canon Ixus 860 lens
hi
If your lens comes out and retracs during power on or off then the spring that closes the lens is either broken or off trac. If you are within warranty period and able to open the case then it should be an easy fix. If not then you would have to get it repaired.
all the best.
thankyou.
May 05, 2009 | Canon IXUS 860 IS Digital Camera
Hi there .. I have had this camera for a couple of years now and it as been fabulous however a couple of weeks ago, i went to turn it on and it made a churning noise, and then reported on its blank...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 17, 2009 | Canon IXUS 860 IS Digital Camera
Lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 14, 2008 | Canon IXUS V2 Digital Camera
Lens error
Oct 23, 2008 | Canon IXUS 860 IS Digital Camera
Canon IXUS 860 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
