Question about Hoover Washing Machines
Hoover dyn8144d led not working
Led is displaying number 8s and wont start any cycles
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: hoover DYN8144D
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jul 06, 2012
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover DYN8144D
Jul 05, 2012 | Hoover Washing Machines
My hoover washer dryer wont start? No power
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Click for tips to repair
Jun 28, 2012 | Hoover Washing Machines
Controller, door interlock and motor replaced. Unit comes on, but does not operate.
Hello Dave,
Welcome to FixYa.
Try this test I posted below and let me know what error you find...if any.
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
Cycle Countdown display alone).
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
1 = Aqua Sensor ("Sensotronic") fault
2 = Heating fault
4 = Filling fault
8 = NTC (temperature sensor) fault
email me at macmarkus@live.ca and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Regards,
Macmarkus :)
Sep 30, 2010 | Bosch SHU5316UC Dishwasher
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Led flashes on then off
did you find out what this problem was?
Dec 07, 2006 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
