Question about Watches
Kahuna watch battery - Watches
Do Coifman watches work by battery or are the solar powered
Do you see a itibiti tiny solar panel in the face of the watch? If not like all watches it uses a tiny button battery
Jun 07, 2016 | Watches
What's the proper battery for my Gucci 6400L?
Ensure the watch battery is dead. A Gucci watch is not exactly a cheap trinket, thus the battery should have a fairly long lifespan before requiring a replacement. Once you see the hands of time stop on the face of your luxury item, you can be sure it is time to purhase a new battery. The typical cost for a new battery starts at $50. There are three categories for a Gucci watch: Automatic watches, quartz watches, and bracelet watches. Depending on the type, you will need a battery that suits one of these classifications. Batteries for Gucci watches can usually be obtained on any discount/surplus website (e.g. eBay, batteryright.com, or the actual Gucci store).
Read more : http://www.ehow.com/how_4966607_change-gucci-watch-battery.html
Jul 03, 2014 | Watches
What is the proper battery for my Gucci Watch model 3000
Don't be cheap!!!! Go to a reputable jeweler. Most of them are very clued up on these watches and they will give you the correct information. There are many types of batteries and sizes of batteries. There are also a variety of movements for battery watches. If the wrong battery is put or forced into the watch you can do damage to the watch and then will become more expensive to fix!!!
Mar 28, 2013 | Gucci Watches
Watch is not workng... i think battery finished. but no battery in India. i am in india . hw can i buy a battery.
these battery's can be ordered online search for SB626 or 377 battery
these are quite cheap but buy the best brands and cheaper battery may leak and damage your watch.
Jun 16, 2011 | Police Twingear Watch
How do you change the battery in a black dice flow watch
You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
How do I set my Kahuna watch. In particular stop the hourly beep
From the Time display press 'Mode' twice or until you get to the Alarm display.
From there press 'Adj' to toggle on/off the Chime and Alarm icons.
May 05, 2009 | Watches
Which watch battery do I use?
There are lots of different size button batteries for watches. I work in a clock shop where we change batteries in watches and I have had people bring the watches into me without batteries and it is really a guessing game. A lot of watches take a #377 battery. You can try that or take it to a place that changes watch batteries and let them figure it out.
Mar 08, 2008 | Watches
Watches Logo
176 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
