Question about Electrolux EMS2487X Convection Microwave Oven
Electrolux Microwave EMS 2487x not heating
The microwave is on but not heating. I can't even find the same size to replace as this model is no longer available.
  • Electrolux Master
  • 19,396 Answers
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Are the doors from electrolux eml38405x microwave oven can fit to electrolux emc38905x?
Replacing the door is one of the most demanding service interventions in the microwave. Substitution is possible only with the original door, otherwise may cause leakage of radiation what is very dangerous.
For identity doors of two different models of the microwave please contact an authorized service center.
Dado
Apr 11, 2015 | Electrolux Microwave Ovens
Is this model still available for purchase, if not what is the mdl # that replaced it?
Brenda, according to the GE website, that model is no longer available. They do have other models of similar size though. I have included a link to their website for that size microwave. Products from GE Appliances
Nov 17, 2014 | Microwave Ovens
EW30MO55HS Electrolux 30"microwave doesn't turn or heat
Good Morning Jody, thank you for your post!
If your Electrolux microwave (EW30M055HS) has power but does not heat, often the possibilities include one of four culprits:
·Power Supply
    ·Plugged into GFI Outlet
    ·Faulty Control Panel
    ·Faulty Magnetron
I always recommend resetting your microwave first. You can do so by unplugging your appliance or flipping the circuit breaker for about 30 seconds and then turn your microwave back on. If your microwave stills does not heat or turn, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
Feb 19, 2014 | Electrolux EW30MO55HS 30" Built-in Drop...
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
The unit will no longer heat food or beverage
if there is no heating function, chances are that the Magnatron has died. repairs are just not worth the money considering that Microwaves can be oicked uo second hand and with warranty from many Cash converter stores and even some retailers who sell refurbished models from $50
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Does not heat
I WOULD SAY REMOVE THE CABINET FIRST AND GO FROM THERE. IF YOU HAVE NO POWER THAN CHECK THE FUSE.
Apr 13, 2009 | Electrolux Over-the-Range Microwave
Electrolux EMS2487X Convection Microwave Oven Logo
495 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
