Question about Gaggia Titanium Espresso Machine
Fill Water Tank
HI I have just purchased my New Automatic Coffee machine, i haven't even had a drop of water go through the machine. I am able to set all the functions like water hardness etc however once that is complete the message that i get is Fill Water tank. I have tried turning it off and starting again, restoring factory settings refilling the tank several times but cannot get it past the message. Any suggestions would be appreciated
  • 1 more comment
  • Sandy Beaman Jul 11, 2007
    I contacted the Gaggia Representative who advised that the new machine did not have a weight sensor in the tank. problem solved
  • Christian999 Dec 16, 2007
    I have a problem with my Titanium machine. It seems like there is somethin wring with the weight sensor in the water tank, because the message Fill Water is there even if the tank is full.
    It seems like the weight sensor do not float up when water is filled in the tank.
  • Anonymous Dec 20, 2007
    fill water message is on. not sure what a weight sensor looks lik.
When we got ours, i took the back off and taped the magnet to the receiver. this ensures that the message vever appears, it is a very poor set up anyway for waht is an excellent machine. We are careful to ensure that we do not run out of water and this has only happened twice in 4 years - ventilate and your away again.
Posted on Feb 07, 2009
It is caused by the magnetic sensor not being in the water container. There is a cap and magnet that goes inside the water container.
Posted on Apr 11, 2008
Get rid of the machine.
Return to the store.
That's what I did, it was defective right out of the box brand new.
Posted on Mar 31, 2008
Hi, I purchased Rancilio Silvia v3. I have overflow of water in water tank. What happens and how can I fix? Thank you.
There is a max fill line mark on the side of the water tank. Fill the water to there or less. Do not fill the water any higher than this line or water will spill out the side where the water inlet hoses run. Also make sure that the tank is not cracked and leaking water.
Apr 26, 2011 | Rancilio Silvia Espresso Machine
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
I just purchased a used Royal Professional. The screen keeps telling me to fill the water tank even though it has water in it. Is there a way to get beyond the message? I can't get it to do anything and...
Hi
Do you have a gray cylinder in the water tank? If you don't that is you problem. That will float when there is water in the tank and tell the machine to work. If its missing or at the bottom, the machine won't work.
Mar 12, 2010 | Saeco Royal Cappuccino Espresso Machine
Decalcifying method
There is an auto button on your machine the double ellipse button, hold down for 5 seconds display will read descale.
Safe Descaling method
1- Always use the right descaling products.
Descaling chemicals purchased from supermarkets may not be suitable for the machine. Use of Vinegar is prohibited by manufacturers. Please read the operating manual. Do not use Cafiza, Cleancaf or PuroCaff. These are coffee cleaners recommended for back flushing coffee machines.
2- Always dissolve the Descaling chemical in a container and pour into the water tank. Never add directly into the water tank. Crystals of chemical will slide into the filter & pump and block the water hose and restrict flow of water.
3- Do not pour solution when the tank it is on the machine. In fully automatic machines, the bean hopper is next to the water tank. The solution / water can accidentally get into the bean hopper and cause serious damage to the grinder.
4- Espresso machines have separate water passage for Hot water from steam pipe and espresso dispensing. Flush the solution from both sides, alternatively. Turn machine on, flush one cup from steam pipe and turn machine off. After a pause of 3 to 5 minutes turn machine on and make one large espresso (4-oz.). Repeat this process until all of the solution in the tank is used up.
This method is best both for semi-automatic & fully automatic espresso machines.
Using Electronic programmed method does only half the job as it flushes descaling solution only through the steam pipe. The machine must be flushed with solution from espresso side as well. Automatic descaling method should be completed by making 6 espresso with or without coffee (using pre-ground cycle when available).
5- Rinse the water tank and fill with fresh clean water. Repeat the rinsing process alternatively until four tanks of water is used up to flush the chemical out.
Caution: Do not leave the machine before completing the rinsing with clean water. The solution left inside will corrode & tarnish metallic surface.
Do not leave Chrome plated objects submerged in descaling solution for more than 10 seconds. The chrome will dissolve and leave the item permanently corroded and black.
Jun 07, 2009 | Gaggia Titanium Espresso Machine
Lines are clogged and the coffee is not coming
Use Scalekleen or other citric acid.
1-
machines.
when available).
metallic surface.
Jun 05, 2009 | Saeco VIA Venezia
Getting ''Fill Water'' message even though Tank is full
Gently remove tank the slide it back in place make sure the back of tank makes good contact with the machine when it is being lowered so that the reed switch can read the magnet in the tank.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
"Fill water tank" prompt
this has happened to me too just yesterday (26 May 2013), I replaced the tank because I was lucky to have kept the spare bits off the old machine I had and it worked fine. Over time, the water gets into the float and corrodes the magnet. Best to just replace the magnet if you can or the whole tank. Good luck
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
S-Class Incanto Sirius
Hi Erika,
Make sure the magnet in the water tank flow up when you fill the water tank.
Open the steam knob and make a cup of water to see if you can make a full cup of water.
if nothing of this help you then i think you have to replace the flow meter in your machine.
Have a nice day.
/Mirran
Aug 11, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
363 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
