Question about Whirlpool Dishwashers
Adg 352/1 ix - Whirlpool Dishwashers
2 Suggested Answers
SOURCE: adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
Posted on May 24, 2010
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
Avery scale manual
Which model do you have? there are many manuals here:
Avery Berkel 1770 service manual http://the-checkout-tech.com/
Avery Berkel 3632USB users manual http://the-checkout-tech.com/
Avery Berkel 6700 series calibration guide manual http://the-checkout-tech.com/
Avery Berkel A-102 instruction manual http://the-checkout-tech.com/
Avery Berkel Conveyor Scale installation manual http://the-checkout-tech.com/
Avery Berkel CX-20 CX-30 CX-34 Series service manual http://the-checkout-tech.com/
Avery Berkel CZ-442 calibration manual http://the-checkout-tech.com/
Avery Berkel CZ-442 user manual http://the-checkout-tech.com/
Avery Berkel DX-342 service and calibration manual http://the-checkout-tech.com/
Avery Berkel E1005 users manual http://the-checkout-tech.com/
Avery Berkel E1010 users manual http://the-checkout-tech.com/
Avery Berkel E1070 Service manual http://the-checkout-tech.com/
Avery Berkel E1070 users manual http://the-checkout-tech.com/
Avery Berkel FX-50 users manual http://the-checkout-tech.com/
Avery Berkel FX-100 and FX-220 service manual http://the-checkout-tech.com/
Avery Berkel FX-220 user manual http://the-checkout-tech.com/
Avery Berkel G-203 user manual http://the-checkout-tech.com/
Avery Berkel G-227 service manual http://the-checkout-tech.com/
Avery Berkel GEC A-702 instruction manual http://the-checkout-tech.com/
Avery Berkel IX-100 IX-110 IX-202 IX-212 IX-300 IX-300P IX-302 IX-302P Operation and programming manual http://the-checkout-tech.com/
Avery Berkel IX-110 and IX-202 and IX-212 user guide manual http://the-checkout-tech.com/
Avery Berkel IX Series Customer Ready manual http://the-checkout-tech.com/
Avery Berkel IX Series parts list manual http://the-checkout-tech.com/
Avery Berkel M Series parts list manual http://the-checkout-tech.com/
Avery Berkel M Series service manual http://the-checkout-tech.com/
Avery Berkel Packscan user manual http://the-checkout-tech.com/
Avery Berkel RD-40RF user manual http://the-checkout-tech.com/
Avery Berkel TT-830 users manual http://the-checkout-tech.com/
Avery Berkel WI-127 service manual http://the-checkout-tech.com/
Mar 01, 2013 | Health & Beauty
I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
Adg 3962 IX showing fault code f2 with flashing
May 24, 2010 | Dishwashers
The turntable and the cassette work but the CD doesn't. Where in Florida can I get it fixed.
Here are several firms that claim to offer electrics repair in your area..
The Cartridge Family - www.cartridgefamilyinc.com - (352) 332-6495 - More
B. Mobile Revolution of Gainesville - www.mobile-revolution.net - (352) 332-2010 - 1 review
C. Appliance Direct - www.appliancedirect.com - (352) 373-0990 - More
D. Ashtin Communications - www.ashtincomm.com - (352) 377-8727 - More
E. Sound Ideas Home Stereo - www.soundideasstereo.com - (352) 378-0192 - 1 review
F. Electronics World - www.electronics-world.net - (352) 332-5608 - 2 reviews
G. Aabbea TV - aabbeatv.com - (352) 373-3614 - 1 review
H. Best Buy - www.bestbuy.com - (352) 379-8500 - 1 review
I. Home Theater Innovations By Bob's TV - www.htibob.com - (352) 245-2183 - More
J. The Laptop Repair - www.thelaptoprepair.com - (352) 374-2984
Please dont forget to rate well ;o) Thank you
Aug 07, 2009 | Philco (R) Classic Turntable CD Shelf...
Purple blotch on screen
hi..This patch can be a result of your TV 's Auto Degaussing
Coil problem. Metallic parts of a TV gets magnetized and the
ADG coil demagnetizes them. At power on you should hear a
sound,which is the ADG coil.please check the ADG coil connector
it might have been pulled out. The ADG coil is wrapped around securely
on your TV's Picture tube and power is tapped directly from the AC
Main via a plug in type connector to the TV main circuit board.
check it out..
thank u..
rate me..
May 04, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Dishwashers Logo
66 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
