Question about Maxi-Cosi Priori
How to adjust the straps
I need to adjust the straps from the bottom to the top
  • Maxi-Cosi Master
  • 1,629 Answers
Hi
Visit www.maxi-cosi.com and select which country you're in, then choose the model carseat you have and go to the Service tab to download a copy of the User Manual which will show how to adjust harness height.
Posted on Aug 17, 2014
2 Suggested Answers
  • 40 Answers
SOURCE: Maxi-Cosi how do you adjust the straps
u can do that first install it in the car and then set ur child and do the rest
Posted on Jun 27, 2007
In need the instructions
This is a seat post mounted bag, with attachments for the rails (2) on the bottom of the seatpost.
1. The straps going over the top of the bag will have to come apart. Removing them from the loop they pass through before re-attaching with the velcro.
2. Undo the straps and then feed them over the metal seat rails.
3. Re-assemble the straps in the same manner they were before and loosely attach the velcro. You will later tighten up the tension on these straps to snug the bag up under the seat.
4. Attach the velcro strap on the posterior of the bag to the seatpost.
5. Now the bag should be supported by the seat post strap and the seat rail straps (2). Hanging loosely and oddly from the seat area.
6. Tighten/snug the straps from step three, so the bag is drawn up against the bottom of the seat. Try adjusting all the straps on the bag until the bag appears to sit well under the seat.
7. DONE
Jan 05, 2013 | Avenir Bigmouth Seat Bag
I need to know how to reset the time. l lost the manual psealy@hattiesburgms.com
On the sides of the watch there should be 4 mode buttons, top left should be Adjust. Push adjust, one part of the display should flash (hour or minutes for example). Push the top or bottom right buttons to adjust up or down. Push the Mode button to move to the next item to set. When all done push the Adjust button again.
Jun 07, 2010 | Casio BabyG Shock Crystal Strap BG361 2B...
K2 Cinch loop leash on top of highback tore. What is the best way to fix it? Glue, saw on, both or order a replacement part. Or leave it alone since it does nothing after adjustment.
The K2 website has a binding technical manual, link was found at the bottom of the K2 home page (see link below). The manual provides NO part numbers and NO repair procedures, but the repair is fairly easy.
http://assets.k2sports.com/k2snow/ftpk2snow/2017/catalogs/k2snowboarding_binding_tech_manual.pdf
The back straps on the K2 Cinch are called "grab loops" as shown in photo below.
If both “grab loops” are broken, take a few photos first so you can recall the routing for installation of the new “grab loops”.
These "grab loops" are held in by two silver coloured roll pins which can easily be tapped out with a small nail & hammer. If the pin doesn't come out easy, tap from the other side of the pin. The pin has a head on one side.
You may need to use pliers to remove the broken piece of strap from the top lever.
Take the broken strap pieces to your K2 retailer ( snowboard shop) and ask them to order a new strap. K2 info suggests you can’t order parts online direct from K2, so you have to order through a K2 retailer.
Use your other binding with the good strap to copy the routing of the new strap. You might want to order two new grab loop straps and change them both while you are at it. ??
Apr 14, 2010 | K2 Cinch CTC Snowboard Binding
Hi there. i have purchased the frootmuff for quinny and there is no instructions. im not sure where the straps attach to on the top and there is 2 slits for the soulder straps to go through when i can only...
the first large hole to the bottom of the footmuff is for the **** pad you will then need to remove top section of straps from the pram which is a slide clip then remove the strap covers at this point you can push the straps in the two lower slits at about bottom height then you will need to put the strap covers back on then fit through either the first or second slits in the cosey toes (depending on height of child) attching he straps back to the pram and you are ready to go also most quinny prams have 2 levels which the shoulder straps can be attched i hope this helps x
Nov 23, 2009 | Quinny ZAPP Stroller
I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
Oct 13, 2009 | Eddie Bauer Deluxe High Back Booster...
Rear Facing UAS strap can't feed through?
Are you sure you're looking at the UAS/LATCH strap and not the top tether?
Your seats should have a long strap with a hook at each end that goes through the belt path (the UAS strap) and another at the top, for top tethering once you turn them forward facing.
The UAS strap may be hooked onto the sides of the seat or bundled together underneath...take another look at your manual to find out where they store it.
Alternately, install with the seat belt - neither LATCH/UAS or seat belt is "safer" than the other...the LATCH/UAS is just supposed to be more convenient.
Jan 03, 2009 | Eddie Bauer 3-In-1 with Latch
I have a 02-442-PRI 11-17-98 Cosco
If you washed the straps, they will need to be replaced. Lock the harness together, to prevent the straps from being twisted. Feed the top part of the harness through the slots that are AT or ABOVE your hangchilds shoulder if the seat is forward facing. IF the seat is for rearfacing, feed the top part of the harness straps through the shoulder slots at or BELOW the child's shoulder. Once each is through, reach down and attach them to the silver plate that hangs from the **** strap adjuster. Once you silde each of the harness straps, then slide the bottom of the through the hole in the cover, then into the base of the seat, folding the top like a triangle makes it easier to get through the tight holes. Repeat on the other side and you are ready to travel! Thanks!
Jun 16, 2008 | Cosco High Back Booster 22-200 /22-207
Evenflo aura travel system
I hope this information helps:
1) There are harness anchors (metal clips) located on the bottom of the seat. Push these up through the slot to the front of the seat on both sides. To do this, you will need to pull them toward you, and then turn the anchors to fit through the slots.
2) You should be able to remove the bottoms of the straps at this point. Remove them, then pull the tops of the straps through the slots. (You will need to remove the buckles during this process.)
3) Slide the straps through the slot you need for the correct harness height.
4) Replace the buckles in the correct positions.
5) Replace the bottoms of the straps into the harness anchors.
6) Push the harness anchors through the padding and back into the bottom of the seat. Clip into place.
Dec 04, 2007 | Evenflo Aura Traditions Travel System...
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Take a look here ,you have the manula and if you want you can get to know the FAQ. Thanks. http://www.maxi-cosi.com/maxicosi/productindex. aspx?cat=p
Jun 23, 2007 | Maxi-Cosi Priori
Maxi-Cosi Priori Logo
100 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
