Question about Neff Ovens
HOW TO REMOVE NEFF HIDE AND SLIDE OVEN DOOR
INSTRUCTION IN THE MANUAL NOT CLEAR PLEASE COULD YOU CLARIFY HOW TO REMOVE THE DOOR FOR CLEANING PURPOSES. THANKYOU
  • 236 Answers
SOURCE: Oven Door Locked
is it locked in the up or down position?
Posted on Jun 04, 2007
hotuna
  • 288 Answers
SOURCE: Hotpoint range door doesn't unlock after the clean cycle.
It is possible that the lever has been bent somehow. If you can lift the top of the oven as if you were cleaning it. look at the lever mechanism, move it to the other position and push it back carefully, to bend it back. I have seen this happen a lot, people lean on the oven, the lever is in the open position and it is pushed a little bending it so when it is moved to close it doesn't go far enough to release it. I am assuming you have waited for the oven to cool down before you tried this first right?
Posted on Dec 06, 2007
  • 417 Answers
SOURCE: looking for installation instructions for a Neff B1691 oven
Neff have some downloadable installation instructions at www.neff.co.uk select neff owners, then customer service, this opens a new window which has instruction manuals as an option, select this and then enter an E number for the model ( i tried B1664) a similar single oven and this brought up a pdf file. At the end p67 it gives cable sizes and types and connection details which should give you what you need.
Please remember to rate this solution.
Posted on Dec 08, 2008
SOURCE: Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Posted on Mar 08, 2009
SOURCE: Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
Posted on Sep 11, 2009
Need a manual for a neff fan assisted oven
Hi, Same can be found on neff website, Please find the same.
http://www.neff.co.uk/getting-started-with-your-neff-oven.html
Aug 25, 2014 | Neff Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Neff slide and hide oven door handle has come off
It's a door-off job. Possible (I've just done it) but it's very fiddly. All the runners and sprung mechanisms are a nightmare.
Dec 10, 2012 | Neff Ovens
How do I sepate the inside from the outside of a neff oven Bl641 door
Remove the oven door by flipping the hinge catches into their alternative position and lift the door out of the hinge slots (note it is somewhat heavy). Lie the door, outside face down and press down on the glass with both hands until it slides off the mounting pins at the base of the door body. Replacement is an exact reversal.
Feb 18, 2012 | Neff B1641 Single circotherm super...
How to remove main oven door on neff u1564
Use link
http://www.neffcustomerservice.co.uk/
click on instruction manual download (bottom left of page) this will open new window, enter U1452 in search box... click on first result and go to page 36 of downloaded PDF this will give you the instructions.
All the best, hope this helps
Aug 30, 2011 | Neff U1452 Double circotherm plus Electric...
I am looking to download a manual for a neff oven,
U HAVE TO TYPE IN GOOGLE DOWNLOAD AN INSTRUCTION MANUAL FOR A NEFF OVEN
Sep 29, 2009 | Neff U1721 Double circotherm Electric Oven
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Looking for installation instructions for a Neff B1691 oven
Dec 08, 2008 | Neff B1691 Single circotherm super...
The inner glass of my sons built in oven door has fallen out can you please advise how we can fix it thank you it is neff b1420
The inner glass panels are bonded to the frame with a heat proof adhesive.
The chances are you will have to get a complete new door assembly.
Jul 22, 2008 | Neff B1421 Electric Single Oven
Ovens Logo
3,691 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
