Error 5800 I cannot print my document because what usually appeared was that error 5800
  • 826 Answers
You can reinstall your driver ..or try to restore your system of earlier day..
Posted on Jan 14, 2013
Riztech
  • 731 Answers
SOURCE: ERROR MESSAGE APPEAR AFTER PRINTER PREPARATION OCURING. THE ERROR MESSSAGE THAT APPEAR , INK SYSTEM FAILURE. INK SYSTEM HAS FAILED. UNABLE TO COPY, RCEIVE FAXES OR PRINT. REFER TO DOCUMENTATION. ERROR
Ink System Failure is a Hardware Issue, which indicates that the Ink Delivery system failed to initialize.
I suggest you to perform the below the troubleshooting steps, if it doesnt fixes, then the printer need to be serviced or replaced.
1.Turn OFF the printer, unplug the power cable and the USB from the printer.Then Press and Hold the ON/OFF button for 1 minute and then reconnect the cables and try again.If it doesnt fixes, goto next step.
2.Remove the ink cartridges, Turn the printer OFF and Unplug all the cables from the back of the printer.Connect the Printer directly to the wall outlet.Turn it on and wait until u get a prompt to insert the ink cartridges.If it didnt work, go to step 3.
3.Remove the ink cartridges again and close the access door.Disconnect the power cable while the printer is ON.Now Press and Hold the OK and CANCEL button.While Holding the OK and CANCEL button insert the power cable and continue holding the button until u get a message "NVM Reset" or untill the printer goes OFF.Then release the buttons and press ON/OFF button.
4.If you still get the same error, then the printer needs to be serviced.
Thanks
Riz
Posted on Apr 17, 2008
SOURCE: HP PHOTOSMART 7180 ALL IN ONE
how to reduce the baud rate in all in one printer
Posted on May 03, 2008
  • 62 Answers
SOURCE: printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Posted on Jan 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: Printing Error...
Hi!
The U052 error means that the 'chip' fitted to the Cartridge is not responding . They fit these chips to try to prevent refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and the chips are particularly sensitive to static / damage. Many people end up blowing the chips during the swap over
Please rate this solution.
Thanks
Rylee
Posted on Feb 10, 2009
  • 125 Answers
SOURCE: I am getting an 5800 error
Ink Absorber Replacement OptionsThis printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to release the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk
the 5800 code. uplug cord from outlet. wait 1 full min, then plug in and let go through self test.
reply for more help.
have a great day and please rate bama46, thank you
Posted on Aug 25, 2009
How do you fix error message 5800?
Hi Marcia
Please try the below instructions and see if it works.
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Regards
Venugopal
Sep 26, 2016 | Canon PIXMA Office Equipment & Supplies
Error 49.33.03
First turn off the printer and then delete the job held at the computer in the print queue. Then turn the printer back on. The error should go away. Try printing the document again to see if the error returns. Normally a corrupt print job causes this issue. If the error appears with no jobs being sent to the printer then the formatter board is most likely bad.
Mar 10, 2014 | HP Color Laserjet Enterprise Cp5525n...
Error code 5800:041A
5800 usually points to a processing issue but most likely its the Motherboard
Feb 17, 2014 | Dell PowerEdge R900 Server (146GB4GB)...
When I want to make a copy it tells me "Paper size
Good day, Regarding the error message that your getting, that means the paper where you want to print that document is not supported by the printer. Usually you'll the see supported paper size if you click the print option or print setup for your printer. The only way to resolve this is to use the appropriate size of paper like.
You can also try this steps to change size for the documents you want to print
>Open the File menu and click Print.
>Click the Settings tab
>Click on Paper Size. A list of paper sizes will appear
>Select the size you want.
>If none of the selections are suitable, select Custom. A box will appear inviting you to set your
own measurements. Enter the width and length that you want.
>Click OK.
These are the usual paper size use. It's 8 1/2 by 11 inches and the other one that you could use in most printers is 8 1/2 by 14. The first one is known as Letter size, the other one is known as Legal size. Hope this information help in resolving your issue. Have a great day.
May 23, 2011 | HP Photosmart 3310 Printer
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
May 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Service Req C0302
CPU Error. Mainboard is faulty.
Jul 04, 2008 | Epson AcuLaser C1900 Printer
jasbo
jasbo
