Question about Brinks 1-7/8 In. SS Dial Combination Lock
94829V60 NEED COMBINATION TO THIS LOCK - Brinks 1-7/8 In. SS Dial Combination Lock
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
RE-SETTING THE CODE
You need a key to unscrew and remove the lock cylinder on the inside of lock. Enter the old combination. Look inside the hole where the lock cylinder was and turn the metal part in there to the right. Then turn the knob or lever to clear the old combination.
Enter your new combination and turn the knob or lever to insure it works. Try it again to be sure, then replace the change plug. Always test combo with the door open.
Apr 22, 2014 | Ilco Kaba 101126d41 Lock Combination
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
I forgot the combination to my master lock box. What do I need to open the box?
If you do not have the combination, try to contact the manufacturer directly. There may be a serial number on the lock that they can match the combination to.
If that does not work, you will need to contact a locksmith.
Apr 20, 2011 | Master Lock : Locking Combination 5-Key...
Master Lock 5400D Key Storage Combination Lock box i reset it combination a couple of days ago and it worked fine until today. Now it won't open with the new combination. How can I get in to it without...
Two solutions: (if the box is closed and it is attached to something)
Jun 25, 2010 | Master Lock 5400d: Portable Select Access...
I lost the combination and can't open it
The only way to open your lock is by using the correct combination: there is no other way.
You can either try every possible combination or you will need to contact the manufacturer. But they cannot assist you if the lock does not have a serial number (they recently stopped applying serial numbers for greater security) and they will not assist if the lock is already secured to anything. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination.
Jul 07, 2010 | Master Lock 5400d: Portable Select Access...
Brinks 1-7/8 In. SS Dial Combination Lock Logo
29 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
