Question about Car Audio & Video
Having problems with alpine cde-w233r stereo can't get any sound have got the wiring sable
SOURCE: SET CLOCL
Hold in title button on the bottom right hand corner
Posted on Apr 16, 2008
SOURCE: alpine cde-7853
hold down display button until time is blinking, about 20 - 30 seconds. to change hour press 5 button, to change minutes press 6 button. get time set then press display button again.
Posted on Jun 18, 2008
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
SOURCE: can't set the clock
Pasted from the manual:
TITLE/ for at least 2 seconds while the time is
displayed.
2 Turn the Rotary encoder (CDE-9846 only) or
press
up or down arrow (CDE-9842 only) to adjust the
Rotary encoder (CDE-9846 only) or press MODE
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
press
pressing the Rotary encoder (CDE-9846 only) or press
MODE (CDE-9842 only).
Posted on Dec 03, 2008
etirbynnor
  • 655 Answers
SOURCE: adjusting the time on an Alpine CDE-9852
Hello bitterswe834,
To set the time, do this:
1. Press TITLE repeatedly until the time is displayed.
2. Press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink.
3. Use the volume control to adjust the hours while the time indication is blinking.
4. When the hour has been adjusted, press MODE.
5. Turn the volume control to adjust the minutes while the time indication is blinking.
Hope this helps.
Posted on May 24, 2009
Pontiac grand am wiring diagram
You will need the wire harness that is designed to connect to the stock stereo. Another option is to just install your alpine stereo in the car since you have the wiring harness for that. You will not be able to wire the harness for the alpine unit and have it match the plug type for your stock stereo.
Dec 12, 2013 | Alpine CDE-121 In-Dash CD/MP3/WMA/AAC Car...
Is there an adapter I can purchase to be able to play an IPOD with my alpine cde 9841 car cd receiver stereo?
Your headunit doesn't have the option of a plug i Ipod cable, The only way to use it with your stereo is to get an FM Transmitter and you tune into the ipod through the radio.
Mar 06, 2012 | Alpine CDE-9841 CD Player
Hi, I recently purchased a new Stereo deck and I like to remove the old Alpine CDE-7827 deck. My car is a 1995 Ford Thunderbird.
The original wires in the 95' thunderbirds are a pain, trying to figure out how to take out factory stereo and replace with aftermarket Sony cd player, have no clue because the wires don't match up, some do and they will load and unload discs but won't power up any suggestions...?!?
May 24, 2011 | Alpine CDE-7827
I am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Sep 25, 2009 | Alpine Car Audio & Video
After installing the alpine CDE 9870 car stereo there was no sound... although the car speakers work.Maybe the audio in the stereo?Can thatbe fixed?
In this situation 8 times out of 10 the problem is not with the radio, it's that there are factory amplifiers. Many cars have them, and most require a little work, or an adapter to get going. Tell me the year, make, and model of the car, and perhaps I can give you more info.
Aug 09, 2009 | Alpine Car Audio & Video
I get power to the stereo but no sound comes out
Hello eklypss2000,
According to the manual for the Alpine CDE-102, the message "DC ERROR" is displayed if there is a short to ground in the speaker wiring. Check all of your speaker wires and make sure that no bare wire is shorting against the vehicle metal or against other wires. Repair or replace the wire as necessary. After correcting the problem, set POWER IC to "POW ON" according to the instructions in your manual.
Hope this helps.
May 18, 2009 | Alpine Car Audio & Video
Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
Nov 20, 2008 | Alpine CDE-7853
No sound from front speakers during CD operation.
I think you are using an external amplifier,if this is the case,you may be using the wrong remote wire for the amp.
Alpine use two blue wires,BLUE (only) this wire is for the pwr antenna and every time you insert a cd, this pwr line cut out.
BLUE/WHITE STRIPE this is the remote wire that you need to connect the remote of the amplifier.
thanks for rating
Feb 11, 2008 | Alpine CDE-9846 CD/MP3 Car Stereo
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
