Question about Samsung SF 5100 Laser Printer
Help with samsung fs5100
The paper does not feed properly, it is feeding itself on a slant
Samsung SF 5100 Laser Printer iwant this product driver for win xp s.p.2
Posted on Mar 13, 2009
Print out are not proper aligned they are slanted
Have you made sure to keep the paper in the feed tray properly alligned before starting to print?
Jan 17, 2013 | Office Equipment & Supplies
Canon Bubble Jet printer won't feed paper and print properly.
Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
Nov 07, 2009 | Canon BJC-85 InkJet Printer
My printing result slants to the left. how can i resolve this? did maintenance on control panel but does not work.
its very simple dude...!!!!
if your paper feed tray is at the back...
just put your hand into the paper feed tray and you can feel a small roller which rotates very easily.....
just turn it anti-clockwise(it is unidirectional-turns only one way) adjust it a little and print something white and notice if the paper is drawn in slant...!!!
Sep 05, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My paper loads on a slant and then says there's a paper jam. The paper is in straight but won't load straight.
Try cleaning the paper roller feeds with something like white spirt as this helped me
Aug 04, 2009 | Office Equipment & Supplies
Computer keeps saying "paper out" or "not loaded properly"
disconnect the printer from the computer
do a manual paper feed
if it can feed paper, replace usb cable or try another usb port
May 14, 2009 | Epson CX8400 All-In-One InkJet Printer
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
My computer isn't printing the way it should. It is a CANNON 1800
Hello michelle9mit,
First of all you will need to clean the surfaces of the DRUM, and paper feed path and assembly. This might be the cause of most of your problems. I would suggest also making sure the paper feed sensors are cleaned and tested for the proper voltage levels. As far as the slanting paper the paper feed mechanism may have to be cleaned and aligned. I would also make the suggestion that if you do not have a mechanical background you should get a professional service center to do the work for you, but first get an estimate on the cost and if it is too much, you may want to consider getting a new printer and getting a maintenance plan for it.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 14, 2009 | Dell 3100cn Laser Printer
Cant get paper to feed on samsung clx 2160n
Most such printing problems stem from incorrect paper types or paper loading. Make sure that your paper is loaded properly, and that the paper type is made for your specific printer.
Check the hardware.
If paper is not feeding properly into the printer, the problem may stem from hardware failure. Check the feed assembly to see if all the parts are in working order. You may be able to manually advance the paper in order to see which component may be failing. If necessary, clean the paper pickup rollers to make sure the paper path is free of sticky dirt and debris.
Jun 27, 2008 | Samsung Office Equipment & Supplies
HP 1020
Check that paper and paper tray are installed correctly. Print from MP tray and check if it's still slanted. If not, the problem is related to the tray and the feed rollers for the tray. Check also these feed roller and separation pad.
Jul 31, 2007 | HP LaserJet 1020 Printer
Samsung SF 5100 Laser Printer Logo
234 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
