Aficio mp 3350 printing on both sides of paper
I am trying to get my printer to print single side pages not on both sides of the paper. Can't find anywhere in the settings to change it.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Please go to Start Menu from your PC;
  • Click on Printer and Faxes;
  • Press right button of mouse on the Aficio MP3350 driver;
  • Select Printing preferences;
  • Find Duplex: and open the window below and select Off.
  • Click on Apply
  • then OK and exit.
You should print on single sided copies now.
Good luck and please rate me, thanks.
Posted on Jan 23, 2009
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Double sided printing
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 14, 2012 | HP Photosmart Plus All In One Printer b210
I use my MF6530 Laser Copier Printer to print checks and it will frequently print on the reverse side of the paper.
hai I give print to printer 2 side in single page, first two page print well but another two page print in opposite direction in the same paper (example1,2 page one side and 3 ,4 pages in other side but reverse direction. it mean you turn the paper to next side, you see opposite direction ) please help me to avoid this problem.
Jul 22, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
How we print a document on both sides (back and front) of the paper in RICOH Aficio MP 2000L copier
Hello!
If your machine have that option you just need to go to the printer properties and select the duplex.
If you have any doubt reply to me.
See you!
Jul 07, 2011 | Ricoh Aficio MP 1600 Black and White...
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
Using the PCL drivers for our Ricoh Aficio MP 3350
Try using the RPCS (Ricoh's proprietary print driver) for printing from Word, and see if that works any better. You could also try another version of PCL -- if you're using PCL6, try PCL5, for example.
All of the 3350 drivers can be downloaded here (just choose the correct operating system):
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/mp33/mp33en.htm
Dec 02, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How can i get my pixma mp 620 printer to print on both sides of the paper
If the printer does not support double sided printing, you need to take the printed page and put it back into the paper tray upside down to print on the other side of the page.
If you have a document several pages long then you need to print a page at a time. The odd page on one side and the even page on the other side.
Sep 17, 2009 | Canon PIXMA MP620 All-In-One InkJet...
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
302 people viewed this question
jasbo
jasbo
