NEED THE PIN CODE FOR A 1991 MITSUBISHI MODEL # VS-4003R PROJECTION TV
  • 21 Answers
Hello, If you're recieving satellite tv, there a selection in your menu which will give you those codes, but I think the code is # 080.
I hope this helps.
Posted on Jan 23, 2009
Code to unlock VS-4003R
Go into the Menu and in one of the set up pages see if it has a selection for monitor. If it does, change it to tuner.
Hope this helps,
Skyassoc
Jun 20, 2009 | Televison & Video
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi projection TV VS-4561 Vertical Hold issue
Good Day, Maybeitstime:
Joe the cheapest way is to repair it yourself and this is what you need to do:
VERTICAL JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTIC's (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND). As you can see this might be over you head but for a 1994 model you did get 14 years of watching TV enjoyment. 'Might think about replacement. Good Luck, big IRISH.
Apr 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV Code
you can get the actual remote for that model at www.replacementremotes.com just enter the model number. You may need the service manual to actually erase that code.
Apr 08, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Mitsubishi Vs-50605 TV dead
First thing on a Dead VZ7 to check is the solder connection at the yokes "DY" Connector. Then Check C411 2200uf @ 35V
Then C412 10uf @50V. Then Check IC700 Pin 20 for 0VDC any voltage other than 0VDC on that pin means Diode D980 is leaky.
Hope this helps. If you need anything further let me know.
Jan 15, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Lockout
have a tech lift off the eeprom or the microchip out of the set,that will rset your tv.and bring it back to normal.good luck.
Apr 06, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Need pin code
I would get a generic remote and program it for your set. If you mean that you don't know the security pin which you created for the set you could have big problems. If you are talking about the factory pin, that is usually in the operation manual or you can contact the company. Generally the factory pins are simple like 1,2,3,4.
Jun 19, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
